[postgis-devel] AddRasterConstraints failing to create extents in raster_column view
Bborie Park dustymugs at gmail.com
Fri Apr 19 07:17:20 PDT 2013
Based upon the message, I'm guessing you didn't upgrade the SQL.  Run
the script: rtpostgis_upgrade_20_minor.sql.
-bborie
On Thu, Apr 18, 2013 at 10:48 PM, ryagz <raghavendra at vizexperts.com> wrote:
> Hi,
> I uninstalled postgis 2.0.1 and installed 2.0.3. and ran the query. The
> result is still the same
> NOTICE:  Unable to get the extent of a sample raster
> Total query runtime: 1668838 ms.
> 1 row retrieved.
> can u suggest what would be wrong?
> View this message in context: http://postgis.17.x6.nabble.com/AddRasterConstraints-failing-to-create-extents-in-raster-column-view-tp5003029p5003051.html
> Sent from the PostGIS - Dev mailing list archive at Nabble.com.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
