[postgis-devel] AddRasterConstraints failing to create extents in raster_column view
Bborie Park dustymugs at gmail.com
Mon Apr 22 08:13:35 PDT 2013
The number of rows itself wouldn't be the problem.  What is the exact
error message you getting in 2.0.3?
-bborie
On Mon, Apr 22, 2013 at 1:52 AM, ryagz <raghavendra at vizexperts.com> wrote:
> Hi,
> This is pretty strange, I have Freshly uploaded with postgis 2.0.3 and i am
> still getting the same error.
> One more observation which i have made is extents constraints has failed
> only when i gave tile size 64*64, it is succeeding for case when tiles size
> is 128*128 and 256*256.
> The number of rows in 128*128 is 549120 and  in 64*64 is 2190390. Would the
> reason for the error be too many number of rows in the table?
> -Ryagz
> View this message in context: http://postgis.17.x6.nabble.com/AddRasterConstraints-failing-to-create-extents-in-raster-column-view-tp5003029p5003070.html
> Sent from the PostGIS - Dev mailing list archive at Nabble.com.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
