[postgis-devel] AddRasterConstraints failing to create extents in raster_column view
ryagz raghavendra at vizexperts.com
Mon Apr 22 22:52:08 PDT 2013
I ran the query and the result is :
"PostgreSQL 9.1.6, compiled by Visual C++ build 1500, 32-bit POSTGIS="2.0.3
r11128" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL
1.9.2, released 2012/10/08" LIBXML="2.7.8" LIBJSON="UNKNOWN" (core procs
from "2.0.1 r9979" need upgrade) RASTER (raster procs from "2.0.1 r9979"
need upgrade)"
In the history there is this message:
-- Executing query:
SELECT version() || ' ' || postgis_full_version();
NOTICE:  Function postgis_topology_scripts_installed() not found. Is
topology support enabled and topology.sql installed?
Total query runtime: 12 ms.
1 row retrieved.
I am not sure if my postgreSql is enterprise DB i downloaded the setup from
the website long time back. Can you let me know how to find if its
enterprise DB or not. So that i will check and let you know.
View this message in context: http://postgis.17.x6.nabble.com/AddRasterConstraints-failing-to-create-extents-in-raster-column-view-tp5003029p5003090.html
Sent from the PostGIS - Dev mailing list archive at Nabble.com.
