[postgis-devel] Debbie is mad at me, why?
Bborie Park dustymugs at gmail.com
Fri Aug 16 13:27:00 PDT 2013
Server related. Sounds like Debbie needs the JVM restarted.
-bborie
On Fri, Aug 16, 2013 at 12:41 PM, Nicklas Avén
<nicklas.aven at jordogskog.no>wrote:
> My fix for #2431 r11807 seems to harm Debbie.
> It is PostgreSQL 9.0 and PostGIS 2.1 that errors
> I have some difficulties to get to the bottom of the problem with Debbie
> but i think that she is yelling something like:
> Started by upstream project "PostGIS_Regress" build number 2475
> Building in workspace /var/lib/jenkins/workspace/pg
> [pg] $ /bin/bash /tmp/hudson1248418341796386426.sh
> FATAL: command execution failed
> java.io.IOException: Cannot run program "/bin/bash" (in directory
> "/var/lib/jenkins/workspace/pg"): java.io.IOException: error=12, Cannot
> allocate memory
>         at java.lang.ProcessBuilder.start(ProcessBuilder.java:475)
>         at hudson.Proc$LocalProc.<init>(Proc.java:244)
>         at hudson.Proc$LocalProc.<init>(Proc.java:216)
>         at hudson.Launcher$LocalLauncher.launch(Launcher.java:709)
>         at hudson.Launcher$ProcStarter.start(Launcher.java:338)
>         at hudson.Launcher$ProcStarter.join(Launcher.java:345)
>         at
> hudson.tasks.CommandInterpreter.perform(CommandInterpreter.java:82)
>         at
> hudson.tasks.CommandInterpreter.perform(CommandInterpreter.java:58)
>         at
> hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:19)
>         at hudson.model.AbstractBuild
> $AbstractBuildExecution.perform(AbstractBuild.java:717)
>         at hudson.model.Build$BuildExecution.build(Build.java:199)
>         at hudson.model.Build$BuildExecution.doRun(Build.java:160)
> $AbstractBuildExecution.run(AbstractBuild.java:499)
>         at hudson.model.Run.execute(Run.java:1502)
>         at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
>         at
> hudson.model.ResourceController.execute(ResourceController.java:88)
>         at hudson.model.Executor.run(Executor.java:236)
> Caused by: java.io.IOException: java.io.IOException: error=12, Cannot
> allocate memory
>         at java.lang.UNIXProcess.<init>(UNIXProcess.java:164)
>         at java.lang.ProcessImpl.start(ProcessImpl.java:81)
>         at java.lang.ProcessBuilder.start(ProcessBuilder.java:468)
>         ... 16 more
> Build step 'Execute shell' marked build as failure
> Finished: FAILURE
> Is it a real problem with the code or is it some server-related problem?
> Thanks
> Nicklas
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130816/cda69659/attachment.html>
