[postgis-devel] Debbie is mad at me, why?
Paragon Corporation lr at pcorp.us
Fri Aug 16 13:55:34 PDT 2013
Probably she's been up for months.  I'll save her image and then give her a
reboot.
  _____
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Bborie Park
Sent: Friday, August 16, 2013 4:27 PM
To: nicklas.aven at jordogskog.no; PostGIS Development Discussion
Subject: Re: [postgis-devel] Debbie is mad at me, why?
Server related. Sounds like Debbie needs the JVM restarted.
-bborie
On Fri, Aug 16, 2013 at 12:41 PM, Nicklas Avén <nicklas.aven at jordogskog.no>
wrote:
My fix for #2431 r11807 seems to harm Debbie.
It is PostgreSQL 9.0 and PostGIS 2.1 that errors
I have some difficulties to get to the bottom of the problem with Debbie
but i think that she is yelling something like:
Started by upstream project "PostGIS_Regress" build number 2475
Building in workspace /var/lib/jenkins/workspace/pg
[pg] $ /bin/bash /tmp/hudson1248418341796386426.sh
FATAL: command execution failed
java.io.IOException: Cannot run program "/bin/bash" (in directory
"/var/lib/jenkins/workspace/pg"): java.io.IOException: error=12, Cannot
allocate memory
        at java.lang.ProcessBuilder.start(ProcessBuilder.java:475)
        at hudson.Proc$LocalProc.<init>(Proc.java:244)
        at hudson.Proc$LocalProc.<init>(Proc.java:216)
        at hudson.Launcher$LocalLauncher.launch(Launcher.java:709)
        at hudson.Launcher$ProcStarter.start(Launcher.java:338)
        at hudson.Launcher$ProcStarter.join(Launcher.java:345)
        at
hudson.tasks.CommandInterpreter.perform(CommandInterpreter.java:82)
        at
hudson.tasks.CommandInterpreter.perform(CommandInterpreter.java:58)
        at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:19)
        at hudson.model.AbstractBuild
$AbstractBuildExecution.perform(AbstractBuild.java:717)
        at hudson.model.Build$BuildExecution.build(Build.java:199)
        at hudson.model.Build$BuildExecution.doRun(Build.java:160)
$AbstractBuildExecution.run(AbstractBuild.java:499)
        at hudson.model.Run.execute(Run.java:1502)
        at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
        at
hudson.model.ResourceController.execute(ResourceController.java:88)
        at hudson.model.Executor.run(Executor.java:236)
Caused by: java.io.IOException: java.io.IOException: error=12, Cannot
allocate memory
        at java.lang.UNIXProcess.<init>(UNIXProcess.java:164)
        at java.lang.ProcessImpl.start(ProcessImpl.java:81)
        at java.lang.ProcessBuilder.start(ProcessBuilder.java:468)
        ... 16 more
Build step 'Execute shell' marked build as failure
Finished: FAILURE
Is it a real problem with the code or is it some server-related problem?
Thanks
Nicklas
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130816/7392908d/attachment.html>
