[postgis-devel] GEOS 3.4.1 is out
Devrim GÜNDÜZ devrim at gunduz.org
Tue Aug 20 00:20:16 PDT 2013
On Sat, 2013-08-17 at 13:58 -0400, Paragon Corporation wrote:
> The GEOS development team is proud to release GEOS 3.4.1 which you can
> download from: http://download.osgeo.org/geos/geos-3.4.1.tar.bz2
I cannot build 3.4.1 on any on my Red Hat / Fedora versions:
/usr/bin/libtool --tag=CXX   --mode=link g++ -DGEOS_INLINE  -pedantic -Wall -ansi -Wno-long-long  -ffloat-store -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -no-undefined  -module -avoid-version -L/usr/lib64  -o geos.la -rpath /usr/lib64/ruby/site_ruby/1.8/x86_64-linux geos_la-geos_wrap.lo ../../capi/libgeos_c.la -llibruby.so.1.8.7
libtool: link: g++ -shared -nostdlib /usr/lib/gcc/x86_64-redhat-linux/4.4.4/../../../../lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/4.4.4/crtbeginS.o  .libs/geos_la-geos_wrap.o   -Wl,-rpath -Wl,/var/lib/pgsql/rpm/BUILD/geos-3.4.1/capi/.libs -Wl,-rpath -Wl,/var/lib/pgsql/rpm/BUILD/geos-3.4.1/src/.libs -L/var/lib/pgsql/rpm/BUILD/geos-3.4.1/src/.libs -L/usr/lib64 ../../capi/.libs/libgeos_c.so /var/lib/pgsql/rpm/BUILD/geos-3.4.1/src/.libs/libgeos.so -llibruby.so.1.8.7 -L/usr/lib/gcc/x86_64-redhat-linux/4.4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.4.4/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.4.4/../../.. -lstdc++ -lm -lc -lgcc_s /usr/lib/gcc/x86_64-redhat-linux/4.4.4/crtendS.o /usr/lib/gcc/x86_64-redhat-linux/4.4.4/../../../../lib64/crtn.o  -m64 -mtune=generic   -Wl,-soname -Wl,geos.so -o .libs/geos.so
/usr/bin/ld: cannot find -llibruby.so.1.8.7
collect2: ld returned 1 exit status
make[6]: *** [geos.la] Error 1
make[6]: Leaving directory `/var/lib/pgsql/rpm/BUILD/geos-3.4.1/swig/ruby'
make[5]: *** [all-recursive] Error 1
make[5]: Leaving directory `/var/lib/pgsql/rpm/BUILD/geos-3.4.1/swig/ruby'
make[4]: *** [all] Error 2
make[4]: Leaving directory `/var/lib/pgsql/rpm/BUILD/geos-3.4.1/swig/ruby'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/var/lib/pgsql/rpm/BUILD/geos-3.4.1/swig'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/var/lib/pgsql/rpm/BUILD/geos-3.4.1'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/var/lib/pgsql/rpm/BUILD/geos-3.4.1'
error: Bad exit status from /var/tmp/rpm-tmp.ArIB3V (%build)
This message appears in Fedora boxes -- the only difference is the
libruby version number.
Am I doing anything wrong?
Regards,
Devrim GÜNDÜZ
Principal Systems Engineer @ EnterpriseDB: http://www.enterprisedb.com
PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
Community: devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
http://www.gunduz.org  Twitter: http://twitter.com/devrimgunduz
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130820/550c7545/attachment.sig>
