[postgis-devel] bug with postgis backend
Rémi Cura remi.cura at gmail.com
Mon Dec 9 07:29:57 PST 2013
Hey Olivier ,
this is why I spoke of an "anecdotal" bug :
You have to do a lot's of bad things to make it happens!
I wasn't thinking it should be corrected, after all if you delete al
postgis library postgis stops to work... You can't protect against a very
bad usage.
If you consider it important I could try to reproduce, but it's probably
going to be dirty.
I'm guessing you have more important matters on your todo list =)
Cheers,
Rémi-C
2013/12/9 Oliver Courtin <olivier.courtin at oslandia.com>
> Le 3 déc. 2013 à 17:41, Rémi Cura a écrit :
> Hi Rémi,
> an exotic and anecdotal bug:
> I deleted all tables in a schema (not postgis schema) using cascade.
> I used several connection with pgadmin.
> Then I couldnt use any ppostgis function with the error "trying to set
> postgis.backend"
> setting or resetting postgis.backend wouldn't do anything.
> I add to close all and restart everything.
> I think this may be related to having the postgis.backend set to sfcgal
> with some connection while having other to geos, and recompiling postgis
> without sfcgal
> I don't really understand what you really did.
> You mention deleting tables,
> then recompiling postgis without sfcgal.
> Could you on your own platform reproduce it ?
> BTW:  Opening a ticket is the right way to handle thing like that.
> O.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131209/34549991/attachment.html>
