[postgis-devel] PostGIS 3D - Points to be discussed
Hugo Mercier hugo.mercier at oslandia.com
Mon Feb 4 07:50:42 PST 2013
Hallo Nicklas,
Le 04/02/2013 00:09, Nicklas Avén a écrit :
> Hallo Olivier and Hugo
> First about solids. I am still confused. What tells if a closed
> polyhedral surface is a surface or a solid?
There is a 'flag' field within the LWGEOM structure (and GSERIALIZED as
well). It is not broadly used, but it is here. Setting this flag on says
the polyhedral surface must be considered as a solid. (If the polyhedral
is open, it is not valid).
This is not exported to WKB/WKT, but exists when PostGIS functions are
called (through GSERIALIZED). SFCGAL supports it. You can for instance
use the 'sfcgal.ST_MakeSolid' function to turn a Polyhedral surface into
a Solid and apply algorithms on volumes rather than on surfaces.
We alos support 'SOLID' type in WKT. Maybe we should consider extending
WKB with such a solid support.
If something has to be modified in PostGIS regarding solids, I would
vote for a whole new 'Solid' type which would also carry interior shells
(which is not possible for now with a simple flag).
> Next about planes.
> When I wrote the distance code for 3D I was struggling some with how to
> handle tha plane of a surface. If there is more than three 3D points
> defining a plane it will in most cases not be coplanar caused by
> precision errors.
> Maybe we should consider a WKB/WKT extension to support SOLID
> Then no matter how good the algorithm is for calculating the distances,
> the answer will not be exact since the stored points defining the
> surface is not coplanar.
> In the 3D distance calculations in PostGIS today some average plane is
> calculated. But if it is a need for exact distance values I guess that
> will be a problem.
We faced a similar problem when we had to compute normals of an
arbitrary polygon. We used the Newell's formula, which is a least
squares fit.
> I can only see two ways around that to really get exact calculations.
> 1) store some definition of the plane in the geometry
> 2) define 3 points in the geometry that defines the plane. The rest of
> the points is regarded as 2D points.
> In the second way of doing it the 2D points will not always be xy points
> but xy, xz and yz points depending on the plane.
I am not sure to understand the second way. Can you provide some example ?
CGAL has no direct support for distance 3D functions. Our distance3D
method is for now quite simple. We decompose the geometry using
triangulation and compute distance to triangles.
Hugo Mercier
Oslandia
