[postgis-devel] PostGIS 2.1 "transaction control statements"
Stephen Mather mather.stephen at gmail.com
Fri Feb 8 19:59:57 PST 2013
select version() || ' ' || ' ' || postgis_full_version();
yields
PostgreSQL 9.1.7 on x86_64-unknown-linux-gnu, compiled by gcc
(Ubuntu/Linaro 4.7.2-2ubuntu1) 4.7.2, 64-bit  POSTGIS="2.1.0SVN r11081"
GEOS="3.4.0dev-CAPI-1.8.0 r3762" PROJ="Rel. 4.7.1, 23 September 2009"
LIBXML="2.8.0" LIBJSON="UNKNOWN"
Looking through my history, it was an SVN pull:
svn checkout http://svn.osgeo.org/postgis/trunk/ postgis-2.1.0SVN
cd postgis-2.1.0SVN/
./autogen.sh
./configure --with-gui --with-topology
./configure --with-gui --without-raster --with-topology
make
make comments
make cheatsheets
sudo make install
sudo ldconfig
sudo make comments-install
:D  Looks like I was feeling my way around in the dark a bit there... .
On Fri, Feb 8, 2013 at 10:20 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Which version of trunk are you running with and where did you get it from:
> Direct from svn or tar ball (and if tar ball what link)?
> I just tried with Winnie's 9.2 latest Windows build built fresh whenever
> there is a change and it installed fine creating a new postgis. Didn't try
> 9.1 though.
> PostgreSQL 9.2.2, compiled by Visual C++ build 1600, 64-bit
> POSTGIS="2.1.0SVN r11085" GEOS="3.4.0dev-CAPI-1.8.0 r0" PROJ="Rel. 4.8.0, 6
> March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.8"
> LIBJSON="UNKNOWN" RASTER
> If you are running an older -- its possible there was a temporary issue
> that was fixed, though I'm not aware of one.
> In the make sed strips out all BEGIN COMMITS as well as a bunch of other
> things that are illegal in extension scripts and replaces them with
> equivalent extension commands.  It also adds additional helper functions it
> uses during the process and then drops after.
> *From:* postgis-devel-bounces at lists.osgeo.org [mailto:
> postgis-devel-bounces at lists.osgeo.org] *On Behalf Of *Stephen Mather
> *Sent:* Friday, February 08, 2013 5:13 PM
> *To:* PostGIS Development Discussion
> *Subject:* Re: [postgis-devel] PostGIS 2.1 "transaction control
> statements"
>  -- $Id: postgis.sql.in.c 10806 2012-12-06 17:56:37Z pramsey $
> BEGIN;
> Yes, the BEGIN and END are there.  So, how does it work?  In the MAKE of
> the extension, sed is supposed to strip out all transaction statements, or
> this just slipped into the SVN somehow?
> Best,
> Steve
> On Fri, Feb 8, 2013 at 4:37 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> Hmm that's the same version I'm runnning though I'm running mine under
>> mingw.
>> I thought maybe you were having a sed issue that someone else complained
>> about, though they were on Mac and had to do with sed compatibility switch.
>> In your extension folder of your PostgreSQL install,
>> If you open up postgis-2.1.0SVN.sql
>> Does it start with BEGIN and end with a COMMIT;?
>> If it does -- remove those.  The postgis extension build line:
>> sql_bits/postgis.sql: ../../postgis/postgis.sql
>>  sed -e 's/BEGIN;//g' -e 's/COMMIT;//g'  $< > $@
>>  should have done this but it sounds like it didn't for some reason.
>> Those commands aren't legal in an extension script since the extension
>> machinery already wraps an extension in a transaction.
>> Hope that helps,
>> Regina
>> *Sent:* Friday, February 08, 2013 4:24 PM
>> statements"
>>   GNU sed 4.2.1
>> On Fri, Feb 8, 2013 at 3:08 PM, Paragon Corporation <lr at pcorp.us> wrote:
>>> It sounds like the BEGIN /END transaction did not get stripped in your
>>> extension building.
>>> What version of sed do you have?
>>> Thanks,
>>> Regina
>>> http://www.postgis.us
>>> http://postgis.net
>>> *Sent:* Friday, February 08, 2013 9:19 AM
>>> *To:* postgis-devel at lists.osgeo.org
>>> *Subject:* [postgis-devel] PostGIS 2.1 "transaction control statements"
>>>    Hi All,
>>>        Bounce me to users, if appropriate, but I have put together an
>>> SVN build of PostGIS on Ubuntu 12.10 and postgresql 9.1, with GEOS
>>> 3.4.0dev.  All went well in the configure/make/make install mantra.  When I
>>> got to the CREATE EXTENSION step I got the following cryptic message:
>>> "transaction control statements are not allowed with an extension script"
>>> I've had no problem loading PostGIS using the old method with sql
>>> scripts, but thought I'd highlight this oddity in case it was useful and as
>>> yet unreported.
>>> Best,
>>> Steve Mather
>>> postgis-devel mailing list
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130208/4e24fa01/attachment.html>
