[postgis-devel] [raster] Testing out-db and regular blocking
Bborie Park dustymugs at gmail.com
Tue Feb 26 06:47:51 PST 2013
Hey Mateusz,
Which version of PostGIS are you running?  The constraint should be
the same regardless of where the data is store.  But, does the account
running the postgres server have access to the out-db raster?
-bborie
On Tue, Feb 26, 2013 at 5:46 AM, Mateusz Loskot <mateusz at loskot.net> wrote:
> Hi,
> I'm running a simple test:
> - single GeoTIFF, 512x256 pixels, RGB
> - loaded as single image, no cutting into tiles
> I noticed, these two commands set different regular_blocking constraint:
> raster2pgsql     -C -r  -> TRUE
> raster2pgsql -R -C -r  -> FALSE
> Why is that?
> Shouldn't the second command set it TRUE too?
> Here complete story [1]: Bash script loading the raster, raster_columns view
> screenshot linked, gdalinfo output.
> [1] https://gist.github.com/mloskot/5038101
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
