[postgis-devel] 2.0.3 ?
Paul Ramsey pramsey at cleverelephant.ca
Thu Feb 28 10:41:04 PST 2013
fine w/ me
Paul Ramsey
http://cleverelephant.ca
http://postgis.net
On Thursday, February 28, 2013 at 10:39 AM, Bborie Park wrote:
> Raster has no blockers for 2.0.x. + 1 by me.
> On Thu, Feb 28, 2013 at 10:37 AM, Sandro Santilli <strk at keybit.net (mailto:strk at keybit.net)> wrote:
> > I've fixed a memory fault in GeoJSON parser today,
> > worth putting out a new release in the 2.0.3 IMHO.
> > Does anyone have pending blockers ?
> > Changes so far:
> > * Bug Fixes *
> > - #2126, Better handling of empty rasters from ST_ConvexHull()
> > - #2134, Make sure to process SRS before passing it off to GDAL functions
> > - Fix various memory leaks in liblwgeom
> > - #2173, Fix robustness issue in splitting a line with own vertex
> > also affecting topology building (#2172)
> > - #2174, Fix usage of wrong function lwpoly_free()
> > - #2176, Fix robustness issue with ST_ChangeEdgeGeom
> > - #2184, Properly copy topologies with Z value
> > - postgis_restore.pl (http://postgis_restore.pl) support for mixed case geometry column name in dumps
> > - #2188, Fix function parameter value overflow that caused problems
> > when copying data from a GDAL dataset
> > - #2216, More memory errors in MultiPolygon GeoJSON parsing (with holes)
> > - Fix Memory leak in GeoJSON parser
> > * Enhancements *
> > - #2141, More verbose output when constraints fail to be added
> > to a raster column
> > - Speedup ST_ChangeEdgeGeom
> > --strk;
> > postgis-devel mailing list
> > postgis-devel at lists.osgeo.org (mailto:postgis-devel at lists.osgeo.org)
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
