[postgis-devel] Adding a arbitrary ray function to Postgis raster
Paul Ramsey pramsey at opengeo.org
Sat Jan 5 09:30:34 PST 2013
Your suspicion is correct. If you're going to be allocating memory on
that parameter, it needs to be at pointer-to-a-pointer, not just a
pointer.
signature(int param1, int param1 ptr **param3)
Best,
P.
On Sat, Jan 5, 2013 at 4:06 AM, Nathaniel Hunter Clay
<clay.nathaniel at gmail.com> wrote:
> I am writing a function to add the ability get a ray of pixels from a
> raster. To facilitate functions such as line of sight, viewshed and other
> radio wave propagation analysis. The main reason for writing the function in
> c is to ensure that, every pixel along the ray is returned and for the use
> in a future addition of a call back function that returns every ray from a
> centre point to the edge of the raster. However my c is a little rusty and I
> am getting a segmentation fault.
> I have a function that I am passing a pointer to  then allocating memory
> inside the function.
>     count = rt_band_get_ray(band,x1,y1,x2,y2,&npixels);
> Here is the function body:
>     * Processes an array of pixels that fall on the ray from x1,y1 to x2,y2.
>      * @param band : band to be processed
>      * @param x1 : starting x-cordinate ( 0 based )
>      * @param y1 : starting y-cordinate ( 0 based )
>      * @param x2 : ending x-crodinate ( 0 based )
>      * @param y2 : ending y-cordinate ( 0 based )
>      * @param npixels : pointer to array of pixels
>      * @return -1 on error 0 for success.
>      * http://en.wikipedia.org/wiki/Bresenham%27s_line_algorithm
>     int
>     rt_band_get_ray(rt_band band, int x1, int y1, int x2, int y2, rt_pixel
> *npixels )
>       int x;
>       int y;
>       int xinc1;
>       int yinc1;
>       int xinc2;
>       int yinc2;
>       int dx;
>       int dy;
>       int den;
>       int num;
>       int numadd;
>       int curpixel;
>       double pixval;
>       int isnodata = 0;
>       rt_pixel pixel = NULL;
>       int count;
>       dx = abs( x2 - x1 );
>       dy = abs( y2 - y1 );
>       x = x1;
>       y = y1;
>       // considerations for all eight quads
>       if ( x2 >= x1 )  // the x-values are increasing
>           xinc1 = 1;
>           xinc2 = 1;
>       else   // the x-values are decreasing
>         xinc1 = -1;
>         xinc2 = -1;
>       if( y2 >= y1 ) // the y-values are increasing
>           yinc1 = 1;
>           yinc2 = 1;
>       else  // the y-values are decreasing
>           yinc1 = -1;
>           yinc2 = -1;
>       if ( dx >= dy )  // there is at least one x-value for every y-value
>           xinc1 = 0;   //don't change x when numerator >= denominator
>           yinc2 = 0;   // don't change y for every iteration
>           den = dx;
>           num = dx / 2;
>           numadd = dy;
>           count = dx;  // there are more x-values than y-values
>       else
>           xinc2 = 0;
>           yinc1 = 0;
>           den = dy;
>           num = dy / 2;
>           numadd = dx;
>           count = dy;
>       // allocate array
>         if (npixels == NULL)
>          *npixels = (rt_pixel) rtalloc(sizeof(struct rt_pixel_t) * count);
>         else
>          *npixels = (rt_pixel) rtrealloc(*npixels, sizeof(struct rt_pixel_t)
> * count);
>         if (npixels == NULL) {
>           rterror("rt_band_get_ray: Unable to allocate memory for ray
> pixel(s)");
>           return -1;
>       for ( curpixel = 0; curpixel < count; curpixel++) //itterate through
> all pixels on the line
>           // set current pixel to array
>           rt_band_get_pixel(band,x,y,&pixval,&isnodata);
>           pixel = &((*npixels)[curpixel]);
>           pixel->x = x;
>           pixel->y = y;
>           pixel->nodata = isnodata;
>           pixel->value = pixval;
>           num += numadd;  // increase the numerator by the top of the
> fraction
>           if ( num >= den )  // check if numerator >= denominator
>           num -= den;  // calculate the new numerator value
>           x += xinc1;  // change x as appropriate
>           y += yinc1;  // change y as appropriate
>           x += xinc2;   // change x as appropriate
>           y += yinc2;   // change y as appropriate
>       return count; // return number of npixel elements.
> I think I am loosing scope on the memory allocated inside the function. And
> experiencing a segmentation fault. On this line:
>     for ( i = 0; i < count; i++ ){
> -->          pixel = &((*npixels)[i]);
>           results[i] =  pixel->value;
> Am I loosing scope, on the data allocated inside the function? If so how do
> I accomplish, allocating an array inside this function with out loosing
> scope?
> I humbly submit to any questions, comments or suggestions to fixing my code
> or to the entire idea its self.
> Humbly,
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
