[postgis-devel] postgis_restore.pl problem
Sandro Santilli
strk at keybit.net
Thu Jan 24 08:07:02 PST 2013
On Thu, Jan 24, 2013 at 04:51:50PM +0100, Sandro Santilli wrote:
> On Thu, Jan 24, 2013 at 04:25:36PM +0100, Daniele Debernardi wrote:
> > Hi,
> > using the postgis_restore.pl in postgis 2.0.2, I found a problem
> > when he rewrite the spatial table constraints (around line ~230),
> > he skips geometry columns that has upper case letters and than they
> > have double "" around it.
> > changing the line:
> > if ( $subline =~ /CONSTRAINT enforce_srid_/i ) {
> > to:
> > if ( $subline =~ /CONSTRAINT enforce_srid_/i || $subline =~
> > /CONSTRAINT "enforce_srid_/i) {
> > solves the problem considering them too
> Could you try this line please:
> if ( $subline =~ /CONSTRAINT "?enforce_srid_/i ) {
Also, if you look at the .pl file you can see 2 examples, taken from
real world cases of dumps. Could you provide the snippet resulting
from your dump too, for documentation purpose ?
Thank you !
--strk;
http://www.cartodb.com - Map, analyze and build applications with your data
~~ http://strk.keybit.net
