[postgis-devel] Ack! postgis.control is not getting install!
Stephen Woodbridge woodbri at swoodbridge.com
Sat Jun 8 07:03:02 PDT 2013
Hi Dev,
The current postgis-2.1.0beta3dev.tar.gz and svn are not installing the
postgis.control file. The other two control files are there.
Poor Daniel has been setting a travis instance for pgrouting and
puzzling over this issue because we require pulling 2.1 and doing a
local build and install from that for pgrouting. So I guess we running a
postgis build-bot also :)
-Steve
