[postgis-devel] Ack! postgis.control is not getting install!
Paragon Corporation lr at pcorp.us
Sat Jun 8 07:50:43 PDT 2013
Guys,
Sorry about this I'll check on this issue why no control file.  No
postgis-2.1.0beta3dev is not stable.  That is why I put a dev at the end of
it.
The one you want to use for stability has no dev --- postgis-2.1.0beta2
http://www.postgis.net/2013/05/11/postgis-2-1-0beta2
Sorry for the confusion.  I changed from our standard development extension
(SVN to dev) in case one day we won't be using SVN.
As a general rule, we always put our tagged builds on our osgeo download
site.
Thanks,
Regina
  _____
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Daniel Kastl
Sent: Saturday, June 08, 2013 10:16 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Ack! postgis.control is not getting install!
On Sat, Jun 8, 2013 at 11:03 PM, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
Hi Dev,
The current postgis-2.1.0beta3dev.tar.gz and svn are not installing the
postgis.control file. The other two control files are there.
Poor Daniel has been setting a travis instance for pgrouting and puzzling
over this issue because we require pulling 2.1 and doing a local build and
install from that for pgrouting. So I guess we running a postgis build-bot
also :)
Well, Steve told me that the postgis-2.1.0beta3dev.tar.gz is changing every
night, which explains that it worked still 4 days ago. I thought it would be
a "stable" beta.
As a Travis newbie I thought I messed up something with the install script
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de <http://georepublic.de/>
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130608/167243ec/attachment.html>
