[postgis-devel] Ack! postgis.control is not getting install!
Stephen Woodbridge woodbri at swoodbridge.com
Sat Jun 8 16:05:03 PDT 2013
Just pulled the tarball and built it here locally and everything is
running great. Thanks for the assist.
-Steve
On 6/8/2013 4:50 PM, Paragon Corporation wrote:
> Should be fixed now at anyrate.  Wait a couple of minutes for debbie to
> deploy a new tar ball.
> http://trac.osgeo.org/postgis/ticket/2356
> I did took a peek and saw after my change that the extension files were
> generated now.
> -----Original Message-----
> From: postgis-devel-bounces at lists.osgeo.org
> [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Stephen
> Woodbridge
> Sent: Saturday, June 08, 2013 4:25 PM
> To: postgis-devel at lists.osgeo.org
> Subject: Re: [postgis-devel] Ack! postgis.control is not getting install!
> I know the May 23rd tarball worked ok, but I over wrote it with the newest
> download so I don't have that one.
> I can grab beta2 and try that.
> -Steve
> On 6/8/2013 3:34 PM, Paragon Corporation wrote:
>> Steve,
>> Does the
>> Wget
>> http://download.osgeo.org/postgis/source/postgis-2.1.0beta2.tar.gz
>> Work okay.  I still haven't had a chance to test locally.  I verified
>> that the control files are being included in the tar ball but acutally
>> building form svn isn't working either.
>> I checked winnie's installs and noticed the installed version from
>> pg9.3w64 in her folder is dated 6/4/2013 and so are all the sql files
>> which matches with what you are saying.
>> I've ticketed this issue
>> And will try to trace what change broke this.
>> Thanks for catching it though.  We currently have no mechanism in our
>> regression testing to test extensions (so I just do before I package
>> or on various spot checks) so its REALLY great that you guys do.
>> Thanks,
>> Regina
>> http://www.postgis.us
>> http://postgis.net
>> Woodbridge
>> Sent: Saturday, June 08, 2013 11:14 AM
>> OK, Below is what I did and what's in the extensions and contrib
>> directories. I can not install 2.1 at all as an extenstion because the
>> control file and all the sql files are missing.
>> -Steve
>> # old beta3 may 23rd that worked installed cd postgis-2.1.0beta3dev
>> sudo make uninstall cd ..
>> rm -rf postgis-2.1.0beta3dev
>> wget http://postgis.net/stuff/postgis-2.1.0beta3dev.tar.gz
>> tar xzf postgis-2.1.0beta3dev.tar.gz
>> ./configure --with-pgconfig=/usr/lib/postgresql/9.2/bin/pg_config
>> make
>> sudo make install
>> And this is what I now have in my /usr/share/postgresql/9.2/extension/
>> related to postgis.
>> postgis--2.0.0--2.0.3.sql
>> postgis--2.0.0alpha1--2.0.3.sql
>> postgis--2.0.0alpha2--2.0.3.sql
>> postgis--2.0.0alpha3--2.0.3.sql
>> postgis--2.0.0alpha4--2.0.3.sql
>> postgis--2.0.0alpha5--2.0.3.sql
>> postgis--2.0.0alpha6--2.0.3.sql
>> postgis--2.0.0beta1--2.0.3.sql
>> postgis--2.0.0beta2--2.0.3.sql
>> postgis--2.0.0beta3--2.0.3.sql
>> postgis--2.0.0beta4--2.0.3.sql
>> postgis--2.0.0rc1--2.0.3.sql
>> postgis--2.0.0rc2--2.0.3.sql
>> postgis--2.0.1--2.0.3.sql
>> postgis--2.0.2--2.0.3.sql
>> postgis--2.0.3.sql
>> postgis_tiger_geocoder--2.0.0--2.1.0beta3dev.sql
>> postgis_tiger_geocoder--2.0.1--2.1.0beta3dev.sql
>> postgis_tiger_geocoder--2.0.2--2.1.0beta3dev.sql
>> postgis_tiger_geocoder--2.0.3--2.1.0beta3dev.sql
>> postgis_tiger_geocoder--2.1.0beta1--2.1.0beta3dev.sql
>> postgis_tiger_geocoder--2.1.0beta3dev--2.1.0beta3devnext.sql
>> postgis_tiger_geocoder--2.1.0beta3devnext--2.1.0beta3dev.sql
>> postgis_tiger_geocoder--2.1.0beta3dev.sql
>> postgis_tiger_geocoder--2.1.0SVN--2.1.0beta3dev.sql
>> postgis_tiger_geocoder.control
>> postgis_tiger_geocoder--unpackaged--2.1.0beta3dev.sql
>> postgis_topology--2.0.0--2.0.3.sql
>> postgis_topology--2.0.0--2.1.0beta3dev.sql
>> postgis_topology--2.0.0alpha1--2.0.3.sql
>> postgis_topology--2.0.0alpha2--2.0.3.sql
>> postgis_topology--2.0.0alpha3--2.0.3.sql
>> postgis_topology--2.0.0alpha4--2.0.3.sql
>> postgis_topology--2.0.0alpha5--2.0.3.sql
>> postgis_topology--2.0.0alpha6--2.0.3.sql
>> postgis_topology--2.0.0beta1--2.0.3.sql
>> postgis_topology--2.0.0beta2--2.0.3.sql
>> postgis_topology--2.0.0beta3--2.0.3.sql
>> postgis_topology--2.0.0beta4--2.0.3.sql
>> postgis_topology--2.0.0rc1--2.0.3.sql
>> postgis_topology--2.0.0rc2--2.0.3.sql
>> postgis_topology--2.0.1--2.0.3.sql
>> postgis_topology--2.0.1--2.1.0beta3dev.sql
>> postgis_topology--2.0.2--2.0.3.sql
>> postgis_topology--2.0.2--2.1.0beta3dev.sql
>> postgis_topology--2.0.3--2.1.0beta3dev.sql
>> postgis_topology--2.0.3.sql
>> postgis_topology--2.1.0beta1--2.1.0beta3dev.sql
>> postgis_topology--2.1.0beta3dev--2.1.0beta3devnext.sql
>> postgis_topology--2.1.0beta3devnext--2.1.0beta3dev.sql
>> postgis_topology--2.1.0beta3dev.sql
>> postgis_topology--2.1.0SVN--2.1.0beta3dev.sql
>> postgis_topology.control
>> postgis_topology--unpackaged--2.0.3.sql
>> postgis_topology--unpackaged--2.1.0beta3dev.sql
>> postgis--unpackaged--2.0.3.sql
>> And in the contrib I have:
>> ls /usr/share/postgresql/9.2/contrib/postgis*
>> /usr/share/postgresql/9.2/contrib/postgis-2.0:
>> legacy_gist.sql               rtpostgis_upgrade_20_minor.sql
>> legacy_minimal.sql            spatial_ref_sys.sql
>> legacy.sql                    topology_comments.sql
>> postgis_comments.sql          topology.sql
>> postgis_restore.pl            topology_upgrade_20_minor.sql
>> postgis.sql                   uninstall_legacy.sql
>> postgis_upgrade_20_minor.sql  uninstall_postgis.sql
>> raster_comments.sql           uninstall_rtpostgis.sql
>> rtpostgis_legacy.sql          uninstall_topology.sql
>> rtpostgis.sql
>> /usr/share/postgresql/9.2/contrib/postgis-2.1:
>> legacy_gist.sql               rtpostgis_upgrade_20_21.sql
>> legacy_minimal.sql            rtpostgis_upgrade_21_minor.sql
>> legacy.sql                    spatial_ref_sys.sql
>> postgis_comments.sql          topology_comments.sql
>> postgis_restore.pl            topology.sql
>> postgis.sql                   topology_upgrade_21_minor.sql
>> postgis_upgrade_20_21.sql     uninstall_legacy.sql
>> postgis_upgrade_21_minor.sql  uninstall_postgis.sql
>> rtpostgis_legacy.sql          uninstall_sfcgal.sql
>> rtpostgis.sql                 uninstall_topology.sql
>> On 6/8/2013 10:50 AM, Paragon Corporation wrote:
>>> Guys,
>>> Sorry about this I'll check on this issue why no control file.  No
>>> postgis-2.1.0beta3dev is not stable.  That is why I put a dev at the
>>> end of it.
>>> The one you want to use for stability has no dev ---
>>> postgis-2.1.0beta2
>>> http://www.postgis.net/2013/05/11/postgis-2-1-0beta2
>>> Sorry for the confusion.  I changed from our standard development
>>> extension (SVN to dev) in case one day we won't be using SVN.
>>> As a general rule, we always put our tagged builds on our osgeo
>>> download site.
>>> Thanks,
>>> Regina
>>> *From:* postgis-devel-bounces at lists.osgeo.org
>>> [mailto:postgis-devel-bounces at lists.osgeo.org] *On Behalf Of *Daniel
>>> Kastl
>>> *Sent:* Saturday, June 08, 2013 10:16 AM
>>> *To:* PostGIS Development Discussion
>>> *Subject:* Re: [postgis-devel] Ack! postgis.control is not getting
>> install!
>>> On Sat, Jun 8, 2013 at 11:03 PM, Stephen Woodbridge
>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>>       Hi Dev,
>>>       The current postgis-2.1.0beta3dev.tar.gz and svn are not installing
>>>       the postgis.control file. The other two control files are there.
>>>       Poor Daniel has been setting a travis instance for pgrouting and
>>>       puzzling over this issue because we require pulling 2.1 and doing a
>>>       local build and install from that for pgrouting. So I guess we
>>>       running a postgis build-bot also :)
>>> Well, Steve told me that the postgis-2.1.0beta3dev.tar.gz is changing
>>> every night, which explains that it worked still 4 days ago. I
>>> thought it would be a "stable" beta.
>>> As a Travis newbie I thought I messed up something with the install
>>> script ;-)
>>> Daniel
>>> Georepublic UG & Georepublic Japan
>>> eMail: daniel.kastl at georepublic.de
>>> <mailto:daniel.kastl at georepublic.de>
>>> Web: http://georepublic.de <http://georepublic.de/>
>>> postgis-devel mailing list
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
