[postgis-devel] VOTE: Drop GEOS 3.3 support at PostGIS 2.2
Paragon Corporation lr at pcorp.us
Sat Jun 8 20:53:45 PDT 2013
Yes definitely.  I personally think we should require at least 3.4.0 for 2.2
The list of stuff that will be left out for 3.3 users is already too silly
for me at 2.1
 and will be even sillier in 2.2 especially if we get the voroni stuff in
place currently being worked on by Gsoc student.
2.2 to take full advantage would require geos 3.5 actually unless the voroni
stuff is put in before 3.4 goes out the door.
Strk in particular -- your thoughts
Thanks,
Regina
 http://www.postgis.us
 http://postgis.net
-----Original Message-----
Sent: Saturday, June 08, 2013 8:21 PM
To: Paragon Corporation
Subject: Re: [postgis-devel] VOTE: Drop PostgreSQL 9.0 support at PostGIS
2.2
Since we're drawing lines in the sand, should we consider doing one for
GEOS?
-bborie
On Sat, Jun 8, 2013 at 2:07 PM, Paragon Corporation <lr at pcorp.us> wrote:
> I think we discussed this but didn't come to an official consensus.
> Before we branch to 2.2 in the next couple fo weeks, I'd like to get
> this out of the way.
> As I have said reasons for dropping
> 1) Too many PostgreSQL to test and if we ain't going to test it we
> shouldn't be saying we support it.
> 2) Dropping 9.0, all versions left will support extensions which means
> getting rid of that conditional extension check.
> 3) Raster and PostGIS have some legacy code to handle 9.0 in basic
> postgis the knn gist operators are not supported in 9.0 In case of
> raster, Bborie had to put in some logic for 9.0 for the way it handles
> aggregates.
> It will also make the post-check I'm proposing a tad easier as it
> would only do extension testing:
> http://trac.osgeo.org/postgis/ticket/2358
> Thoughts, concerns, vote
> Thanks,
> Regina
> http://postgis.net
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
