[postgis-devel] PostGIS 2.1.0beta3 build issues on Ubuntu 13.04
Bborie Park dustymugs at gmail.com
Tue Jun 25 07:28:22 PDT 2013
Thanks. I'll see about removing that from the configure.
-bborie
On Tue, Jun 25, 2013 at 1:01 AM, Mike Toews <mwtoews at gmail.com> wrote:
> On 25 June 2013 10:32, Bborie Park <dustymugs at gmail.com> wrote:
>> See if your build works by commenting out line 1057 of configure.ac
>> with "dnl". So, change configure.ac with
>> dnl LIBGDAL_DEPLIBS_LDFLAGS=`$GDAL_CONFIG --dep-libs`
>> And then run ./autogen.sh to rebuild the configure script.
> Both 2.2 (trunk) and the 2.1 branch build successfully without GDAL's
> dep-libs (as does the 2.0 branch, which never used it). Both 2.1 and 2.2
> pass all the regression tests, except for a non-raster related test, which
> I'll elaborate in a separate email.
> -Mike
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
