[postgis-devel] Export from schema with pgsql2shp broken for Windows 64?
Jeff Lounsbury jeffloun at refractions.net
Tue Mar 12 15:39:53 PDT 2013
In reference to:
http://postgis.17.n6.nabble.com/Export-from-schema-with-pgsql2shp-broken-for-Windows-64-td4999002.html
Did anyone ever follow up on this, I don't see any open bugs for it and
I am getting the same behavior in my 64-bit Windows install now.
Pgsql2shp.exe (release 2.0.1 (r9979)) says the table doesn't exist but
if I run "\d <schema>.<Tablename>" it lists in a psql window just fine.
Exporting a table in the public schema works just fine.
Cheers,
-Jeff
