[postgis-devel] Which intersection is faster?
Bborie Park dustymugs at gmail.com
Sat Mar 23 10:53:28 PDT 2013
There's not too much difference between 2.0 and 2.1.  I think the
major change is ST_Intersects(raster, geometry) =
ST_Intersects(geometry, raster).  Basically, if one of the arguments
is a geometry, the op is done in geometry space (raster is converted
to a set of geometries).
-bborie
On Sat, Mar 23, 2013 at 10:50 AM, Jorge Arévalo
<jorgearevalo at libregis.org> wrote:
> Many thanks for the quick response. I can see is pretty fast. But, what about previous version of PostGIS? Say 2.0. Is there any significant difference between both versions?
> Jorge Arevalo
> Freelance developer
> http://www.krop.com/jorgearevalo
> http://about.me/jorgeas80
> Enviado con Sparrow (http://www.sparrowmailapp.com/?sig)
> El sábado 23 de marzo de 2013 a las 18:30, Bborie Park escribió:
>> I'd suggest using the variant that runs in raster space. If I
>> remember correctly, some changes have been made to this in 2.1.
>> -bborie
>> On Sat, Mar 23, 2013 at 10:20 AM, Jorge Arévalo
>> <jorgearevalo at libregis.org (mailto:jorgearevalo at libregis.org)> wrote:
>> > Hello,
>> > I don't know if this is a naive question, but in ST_Intersects description (http://postgis.net/docs/manual-2.0/RT_ST_Intersects.html) I read:
>> > "Depending on the order that the raster and geometry is passed to ST_Intersects(), the test will operate in either raster-space or geometry-space. If ST_Intersects(raster, ....), the test is in raster-space (the geometry is converted to a raster). If ST_Intersects(geometry, ...), the test is in geometry-space (the raster is converted to a set of pixel polygons)."
>> > My question: in equal conditions, which version should be faster?
>> > ST_Intersects(raster, vector) --> in raster space
>> > ST_Intersects(vector, raster) --> in vector space
>> > Many thanks in advance,
>> > Jorge Arevalo
>> > Freelance developer
>> > _______________________________________________
>> > postgis-devel mailing list
>> > postgis-devel at lists.osgeo.org (mailto:postgis-devel at lists.osgeo.org)
>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
