[postgis-devel] --with-cgal
Olivier Courtin olivier.courtin at oslandia.com
Mon Mar 25 11:57:48 PDT 2013
On Mar 25, 2013, at 2:48 PM, Paul Ramsey wrote:
> Discussed at the sprint: beginning to bring CGAL into the fold. First step would be adding CGAL to the build, optionally, with --with-cgal. Initial uses could be voronoi diagram generation, and of course enhanced 3D algorithm support.
As we just said here:
 Right now CGAL is a need to 3D algorithm support, but we also need
 SF-CGAL in the middle to be able to interact between PostGIS Simple
 Feature model and CGAL model.
 SF-CGAL is implemented in C++, and should remain as a separate library.
 cf: https://github.com/Oslandia/SFCGAL
O.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130325/1ef9682b/attachment.html>
