[postgis-devel] Dijikstra
Stephen Mather mather.stephen at gmail.com
Fri Mar 29 16:37:27 PDT 2013
Cool.  Yah, it looks like the database integration portion is pretty
light-- just some quick wrappers.
Thanks Paul,
Best,
Steve
On Fri, Mar 29, 2013 at 7:27 PM, Paul Ramsey <pramsey at cleverelephant.ca>wrote:
> The main difficultly in writing something independent and then trying to
> integrate it is that you'll have to define data structures to solve your
> problem and many of them may be duplicated in the postgis code. This makes
> the final integration step more work than one might like.
> The best interest sol'n, IMO, is to build with (and within) liblwgeom,
> ignoring the database piece entirely. You can get something up and running
> there in pure C, put your tests in CUnit, and debug there, and once
> everything is complete binding into the database itself is relatively
> trivial.
> P
> Paul Ramsey
> http://cleverelephant.ca
> http://postgis.net
> On Friday, March 29, 2013 at 4:18 PM, Stephen Mather wrote:
> > Hi All,
> > Assuming I spelled that right... working on wrapping my brain around
> adding Dijikstra to PostGIS, which is a largely pleasant way to ride Amtrak
> back. I had hoped to find something useful in pgRouting as a starting
> point, but it looks to my novice eyes like Dijikstra is dependent on Boost,
> so no dice there.
> > Anyway, in going down this thread, I've started studying
> http://trac.osgeo.org/postgis/wiki/DevWikiMain
> > Hopefully updated these lines correctly:
> > "New functions submitted will have to go into the next minor release
> which is currently (PostGIS 2.0.4).
> > New functions/features that require on disk structural changes will go
> into next major release (PostGIS 2.1)"
> > Anyway, to the topic at hand: regarding function development for a
> noob-- as a starting place, is it more important for me to get a bit of
> functioning code that works on a static dataset, and then figure out how to
> patch that into using liblwgeom etc., or better to understand how to write
> the function from the ground up in the PostGIS way?
> > Thanks,
> > Best,
> > Steve
> > postgis-devel mailing list
> > postgis-devel at lists.osgeo.org (mailto:postgis-devel at lists.osgeo.org)
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130329/f9374d46/attachment.html>
