[postgis-devel] force_sfs
Sandro Santilli
strk at keybit.net
Fri May 10 08:07:47 PDT 2013
On Fri, May 10, 2013 at 04:24:40PM +0200, Olivier Courtin wrote:
> On May 10, 2013, at 3:56 PM, Sandro Santilli wrote:
> > What's the real use of this ? Is it only for GEOS ?
> Well SFCGAL retrieve SFS 1.2 geometry.
> And GEOS could only handle SFS 1.1
> So when you want to nest a SFCGAL function with GEOS ones,
> it could lead to problem (for instance GEOS stop as not
> able to deal with TRIANGLE...)
> First real use case of such a thing was for ST_ConcaveHull,
> when SFCGAL backend enabled, as concave hull
> mix ST_Intersection (SFCGAL), with ST_IsValid (GEOS)
> > Does it need to be exposed to SQL at all ?
> Yeap i think so, except if we choose to silently convert
> SFS 1.2 -> SFS 1.1 types directly before GEOS calls.
> > Note that we have an st_force_collection already
> > which could work for TIN and POLYHEDRALSURFACE
> > (would need to be renamed as well) so it really
> > only seems to be an issue for TRIANGLE.
> Humm that's not exactly the same need,
> as with st_force_collection on a MULTIPOLYGON you will
> have a collection of POLYGON.
> (rather that with ST_ForceSFS, aim is to have pure SFS 1.1
> geometry type)
How about ST_ForceSFS(geometry, '1.1') ?
--strk;
