[postgis-devel] GDAL dependancies - was PostGIS 2.1.0 beta2 is ready
maplabs at light42.com maplabs at light42.com
Mon May 13 15:57:18 PDT 2013
I introduced the idea of dropping MySQL from oridnary GDAL to the devs
a while back for this reason
. but 1.10 proceeded without change in that area..
Minimal GDAL definitely does not need a dozen or two packages ...
This topic is in flux - there is no optimal answer and user
requirements are changing too
in particular, I see standard support for MySQL is drying up in many
corners of OSS land
Brian M Hamin
OSGeo California Chapter
415-717-4462 cell
On Mon, 13 May 2013 14:40:43 -0700, dustymugs <dustymugs at gmail.com> wrote:
On 05/13/2013 01:52 PM, Devrim GÜNDÜZ wrote:
> > > Hi,
> > > On Mon, 2013-05-13 at 16:46 -0400, Paragon Corporation wrote:
> >> Any chance you can just compile one for PostgreSQL/PostGIS so you
> >> don't run into these dependency issues?
> > > Then I will need to maintain about 20+ packages for GDAL dependency... I
> > am trying to use OS packages :(
> > > Still, I wonder why 2.0 does not pick up mysql dependency, but 2.1
> > does...
> > Beats me regarding your 2.0 vs 2.1 situation as there have been only
> minor bug fixes and enhancements to the raster2pgsql loader for 2.1.
> From my digging, it all boils down to libtool.  If you enable debug for
> libtool, you'll see it add the GDAL dependencies.
> -bborie
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
