[postgis-devel] extensions vs contrib
Paragon Corporation lr at pcorp.us
Mon May 13 20:19:13 PDT 2013
> Working on 2.1 RPMs -- and noticed a behavior change. 2.0 installed .sql
files under share/extension directory of PostgreSQL
> installation.
> However 2.1 installs stuff under share/contrib, and I cannot see any
extension related files there.
> Is that expected?
> Regards,
> Devrim GÜNDÜZ
This only happens if you built without raster support or lower than
PostgreSQL 9.1.  Same case as PostGIS 2.0 so you shouldn't be seeing a
difference.
Extension feature is only available if you build with raster support.
Mine installs fine in extension folder.  It also installs scripts in
share/contrib/postgis-2.1
for those who want to install without extension support.
Hope that helps,
Regina
http://www.postgis.us
http://postgis.net
