[postgis-devel] Building the extension on Solaris/amd64
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Sat May 18 14:34:50 PDT 2013
On 18/05/13 18:34, Paragon Corporation wrote:
> While we are at it any chance we can have it stop installing in system
> folders if its not asked for. I don't know how it happens but liblwgeom.a
> and friends always happen to sneak into
> My msys\local\lib during make install and I suspect this is causing
> problems during my regress testing of shp2pgsql-gui on 32-bit
> As noted here: http://trac.osgeo.org/postgis/ticket/2158
Are you executing "make install" as part of the build? If so that's the
correct behaviour from libtool since after all it's creating a system
library.
For the build boxes, I would highly recommend passing the --prefix,
--includedir and --libdir options into your configure statement so that
your binaries are placed in a separate, non-system directory suring
"make install" (see my example earlier in this thread), one for each
version.
Then all you need to do is add this directory to PATH during regression
and then everything will just work without having problems locating
which libraries are correct for each version.
HTH,
Mark.
