[postgis-devel] Building the extension on Solaris/amd64
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Sun May 19 06:40:26 PDT 2013
On 19/05/13 13:38, Paragon Corporation wrote:
> The equivalent tool for ldd on Windows is depends.exe which should show you
> the DLL versions that are being dynamically linked into a .exe file.
>> Note that libtool also creates a copy of liblwgeom.dll (unversioned) which
> points to the latest version which may be what is causing the confusion
> here. I think on Windows a copy of the current version is created because
> Windows can't handle symbolic links (NTFS junctions) correctly.
> It builds statically under windows without me doing anything -- doesn't ever
> build as a separate dll so kind of a non-issue for me except during regress.
> I never ever see a liblwgeom.dll being created.
Eh? What version of libtool have you got installed in MSYS? From memory,
the original one was so old that it was missing a lot of Win* fixes so I
ended up building my own to get .DLL generation working correctly.
ATB,
Mark.
