[postgis-devel] Build warnings on trunk: "array subscript is above array bounds"
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Fri May 31 00:59:38 PDT 2013
On 25/05/13 19:39, Mark Cave-Ayland wrote:
> I had a bit of a play with this over the afternoon, and whilst this
> approach halved the number of warnings, it didn't eliminate all of them.
> In order to solve the problem in its entirety, I had to cast to an
> intermediate typedef with a larger float[] range.
> I've tested the attached patch and get a full regression pass with it
> applied; I've also confirmed that if I alter the macro dimension offsets
> in both the original and this version, then the resulting diffs match
> exactly with or without this patch attached which makes me reasonably
> confident that it's accessing the correct offsets within the underlying
> GIDX float array.
> Sandro/Paul - can you review and test at your end?
Ping? Or is no news good news?
ATB,
Mark.
