[postgis-devel] Build warnings on trunk: "array subscript is above array bounds"
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Fri May 31 01:43:29 PDT 2013
On 31/05/13 09:18, Sandro Santilli wrote:
>> Ping? Or is no news good news?
> +1 for me to push this into current trunk.
> I think it's important to get a warning-free build before 2.1.0 goes final.
Agreed. At the very least with the patch applied here to reduce the
noise, I see one compiler warning for use of an uninitialised variable
in the statistics code which is likely to cause a runtime crash.
ATB,
Mark.
