[postgis-devel] New function ST_DumpSegments?? (was : utility function : linestring -> setof segment)
Rémi Cura remi.cura at gmail.com
Mon Nov 4 00:05:26 PST 2013
I'll submit a patch when I'll also have the "dumpline".
So to have a more coherent upgrade.
Cheers,
Rémi-C
2013/10/31 Rémi Cura <remi.cura at gmail.com>
> Thanks for your suggestions it is very kind.
> Sadly it can't work .
> I thought about something else,
>  I'll simply go the git way from another connection, without firewall.
> Cheers,
> Rémi-C
> 2013/10/30 Sandro Santilli <strk at keybit.net>
>> On Wed, Oct 30, 2013 at 05:40:28PM +0100, Rémi Cura wrote:
>> > I can't use neither svn nor github easily due to very strict firewall.
>> You can clone the git repo over HTTP:
>> git clone http://github.com/postgis/postgis.git
>> > I was thinking about sending only modified files.
>> You can still send diff if you backup the original files
>> before modifying them. Or the whole tree.
>> --strk;
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131104/419c0bed/attachment.html>
