[postgis-devel] SNapPointToLine : GEOS : where is the code for st_intersects between line and point?
Nicklas Avén nicklas.aven at jordogskog.no
Wed Nov 6 01:40:57 PST 2013
I think postgis has native functions for st_intersects when at least one of the geometries is a point. And there is two paths in the code. One that prepares the "not point" geometry if it is to be used multiple times and one that doesn't.
I do not get the idea do far. Is it a tolerance you are implementing?
Best regards
Nicklad
Skickat från min Samsung Mobil
-------- Originalmeddelande --------
Från: Rémi Cura <remi.cura at gmail.com>
Datum: 06-11-2013  8:59  (GMT+01:00)
Till: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Rubrik: [postgis-devel] SNapPointToLine : GEOS : where is the code for st_intersects between line and point?
Hey,
I've been working on a ST_SnapPointToLine for the past week,
by reverse engineering when points are considered to be on line by st_intersect.
The (classic) problem is purely a numerical issue, and I suspect a problem in design of st_intersects.
So far my solution doesn't work for all line, can someone please point me in the right direction in GEOS so I can see if something can be improved regarding precision.
I know where the API is, but I'm looking for the exact part that decide if a point and a line intersects.
Cheers,
Rémi-C
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131106/79b0fc76/attachment.html>
