[postgis-devel] [postgis-users] PostGIS 2.1.1 Released
Devrim GÜNDÜZ devrim at gunduz.org
Mon Nov 11 01:55:13 PST 2013
RPMs are available for PostgreSQL 9.2 and 9.3 (since Friday) at
http://yum.postgresql.org
Regards, Devrim
On Fri, 2013-11-08 at 12:12 -0800, Paul Ramsey wrote:
> Get it while it's hot!
> http://download.osgeo.org/postgis/source/postgis-2.1.1.tar.gz
>  * Important Changes *
> - #2514, Change raster license from GPL v3+ to v2+, allowing distribution of PostGIS Extension as GPLv2.
> * Bug Fixes *
> - #2396, Make regression tests more endian-agnostic
> - #2434, Fix ST_Intersection(geog,geog) regression in rare cases
> - #2454, Fix behavior of ST_PixelAsXXX functions regarding exclude_nodata_value parameter
> - #2449, Fix potential infinite loop in index building
> - #2489, Fix upgrades from 2.0 leaving stale function signatures
> - #2493, Fix behavior of ST_DumpValues when passed an empty raster
> - #2502, Fix postgis_topology_scripts_installed() install schema
> - #2504, Fix segfault on bogus pgsql2shp call
> - #2512, Support for foreign tables and materialized views in raster_columns and raster_overviews
> - #2525, Fix handling of SRID in nested collections
> - #2528, Fix memory leak in ST_Split / lwline_split_by_line
> - #2532, Add missing raster/geometry commutator operators
> - #2533, Remove duplicated signatures
> * Enhancements *
> - #2463, support for exact length calculations on arc geometries
> - #2478, support for tiger 2013
> - #2527, Added -k flag to raster2pgsql to skip checking that band is NODATA
Devrim GÜNDÜZ
Principal Systems Engineer @ EnterpriseDB: http://www.enterprisedb.com
PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
Community: devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
http://www.gunduz.org  Twitter: http://twitter.com/devrimgunduz
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131111/8f49f17f/attachment.sig>
