[postgis-devel] Avoid unnecessary memory copy in gserialized_datum_get_box2df_p
Sandro Santilli strk at keybit.net
Wed Oct 2 08:04:41 PDT 2013
On Wed, Oct 02, 2013 at 08:23:49AM -0600, Paul Ramsey wrote:
> On Wednesday, October 2, 2013 at 8:19 AM, Sandro Santilli wrote:
> > On Wed, Oct 02, 2013 at 07:33:27AM -0600, Paul Ramsey wrote:
> > > The reason I sliced was because we were seeing big pain for larger objects, and also because it seemed to make sense to read just a little piece rather than the whole geometry, particularly if there was a decompress step, or the whole object would have to be read into memory. What's going to happen to us for larger geometries?
> > Reading the patch, we'd still be only slicing larger geometries.
> > The patch basically avoids a palloc for the small geometries case.
> Sounds good to me then
Will you apply then ?
Sounds worth for 2.0, 2.1 and trunk...
Need a ticket ?
--strk;
