[postgis-devel] sfcgal && extensions
Sandro Santilli strk at keybit.net
Thu Oct 3 00:52:31 PDT 2013
On Wed, Oct 02, 2013 at 08:23:08PM +0200, Oliver Courtin wrote:
> Le 1 oct. 2013 à 04:34, Paragon Corporation a écrit :
> > CREATE EXTENSION postgis_sfcgal;
> > should load the functions and switch the backend.  Though not sure how doable that is.
> Load the function, obviously yes.
> switch the backend i would say : why so ?
> it's looks like something the user should do by itself if he want/need to...
Agreed, I would still want to be able to toggle between the two,
even if loading a postgis_sfcgal extension (or loading the .sql file).
--strk;
