[postgis-devel] sfcgal && extensions
Paragon Corporation lr at pcorp.us
Thu Oct 3 14:21:09 PDT 2013
Agree too. Sorry guys I just misunderstood how it worked.  I thought the
sfcgal.sql functions wouldn't work if the postgis.backend was not set to
sfcgal. Now I understand it's just where there is overlap with GEOS
functions is where the backend choice comes into play. Sfcgal only functions
are always serviced by sfcgal of course :)
Thanks for the clarification,
Regina
-----Original Message-----
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Sandro Santilli
Sent: Thursday, October 03, 2013 3:53 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] sfcgal && extensions
On Wed, Oct 02, 2013 at 08:23:08PM +0200, Oliver Courtin wrote:
> Le 1 oct. 2013 à 04:34, Paragon Corporation a écrit :
> > CREATE EXTENSION postgis_sfcgal;
> > should load the functions and switch the backend.  Though not sure how
doable that is.
> Load the function, obviously yes.
> switch the backend i would say : why so ?
> it's looks like something the user should do by itself if he want/need
to...
Agreed, I would still want to be able to toggle between the two, even if
loading a postgis_sfcgal extension (or loading the .sql file).
--strk;
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
