[postgis-devel] SFCGAL : trouble installing
Rémi Cura remi.cura at gmail.com
Mon Oct 14 03:31:54 PDT 2013
Missing logs, of course :
See attachment,
Cheers,
Rémi-C
2013/10/14 Rémi Cura <remi.cura at gmail.com>
> Hey list (and salut SFCGAL guys).
> I would like to use SFCGAL but can't make it work.
> On a Ubuntu 12.04 LTS, Postgres 9.3, postgis 2.1, CGAL 4.2 , SFCGAL 1.0.2.
>    1. I compil &install CGAL : fine
>    2. I configure and compil SFCGAL : fine
>    3. I install SFCGAL : fine (see log)
>    1. I clean postgis : fine
>    2. I configure postgis : strange (see log) **SFCGAL version is marked
>    as 1.0.0 where it should be 1.0.2
>    3. I compil postgis : fine (see log)
>    4. I install Postgis : fine (see log)
> Then I create a new database :
>    - CREATE DATABASE test_sfcgal;
> And try to add postgis
>    - CREATE EXTENSION postgis VERSION '2.1.0';
> Then I get the error message :
>    - "ERROR:  could not load library "/usr/lib/postgresql/9.3/lib/
>    postgis-2.1.so": libSFCGAL.so: cannot open shared object file: No such
>    file or directory"
> Yet libsfcgal.so is in "/usr/local/lib".
> Is it related to the fact that I have two postgres server (9.2 and 9.3, on
> port 5432 and 5433), even if only the 9.3 is running when installing etc?
> I tried to configure postgis with a given sfcgal path : 'usr/local'
> SFCGAL version is not detected in Postgis configure step.
> Then I get error while building postgis (raster section)
> /bin/bash ../../libtool --mode=link gcc -g -O2  -fPIC -DPIC  -Wall
> -Wmissing-prototypes -I../rt_core -I../../liblwgeom  -I/usr/include/gdal
> -I/usr/local/include   ../rt_core/librtcore.a raster2pgsql.o
> ../../liblwgeom/liblwgeom.la -L/usr/lib -lgdal  -L/usr/local/lib -lgeos_c
>  -lc -lm -o raster2pgsql
> libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes
> -I../rt_core -I../../liblwgeom -I/usr/include/gdal -I/usr/local/include
> raster2pgsql.o -o .libs/raster2pgsql  ../rt_core/librtcore.a
> ../../liblwgeom/.libs/liblwgeom.so -L/usr/lib -lgdal -L/usr/local/lib
> /usr/local/lib/libgeos_c.so -lc -lm
> ../../liblwgeom/.libs/liblwgeom.so: undefined reference to
> `sfcgal_linestring_add_point' ....
> I also tried to install SFCGAL in a custom directory ,
> then use the --with-sfcgal=the_directory
> I got the same error while building than when indicating 'usr/local'
> Postgis_full_version() before installing sfcgal :
> POSTGIS="2.1.0 r11822" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6
> March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.8.0" TOPOLOGY
> RASTER
> Any help appreciated, as I tried everything I could think of !
> Cheers
> Rémi-C
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131014/6cba90df/attachment.html>
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking whether we are using the GNU C++ compiler... (cached) yes
checking whether g++ accepts -g... (cached) yes
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking for grep that handles long lines and -e... (cached) /bin/grep
checking for ant... no
checking for cpp... /usr/bin/cpp
checking if g++ supports -Wall... yes
checking if g++ supports -Wmissing-prototypes... yes
checking if g++ supports -ffloat-store... yes
checking for flex... no
checking for lex... no
checking for bison... no
checking for byacc... no
checking ieeefp.h usability... no
checking ieeefp.h presence... no
checking for ieeefp.h... no
checking termios.h usability... yes
checking termios.h presence... yes
checking for termios.h... yes
checking for vasprintf... yes
checking for asprintf... yes
checking for _LARGEFILE_SOURCE value needed for large files... no
checking for perl... /usr/bin/perl
checking for convert... no
configure: WARNING: ImageMagick does not seem to be installed. Documentation cannot be built
checking for xsltproc... no
configure: WARNING: xsltproc is not installed so documentation cannot be built
checking for xmllint... no
configure: WARNING: xmllint is not installed so documentation cannot be checked
checking for dblatex... no
configure: WARNING: dblatex is not installed so PDF documentation cannot be built
configure: WARNING: could not locate Docbook stylesheets required to build the documentation
checking CUnit/CUnit.h usability... yes
checking CUnit/CUnit.h presence... yes
checking for CUnit/CUnit.h... yes
checking for CU_initialize_registry in -lcunit... yes
checking iconv.h usability... yes
checking iconv.h presence... yes
checking for iconv.h... yes
checking for libiconv_open in -liconv... no
checking for iconv_open in -lc... yes
checking for iconvctl... no
checking for libiconvctl... no
checking for pg_config... /usr/bin/pg_config
checking PostgreSQL version... PostgreSQL 9.3.1
checking libpq-fe.h usability... yes
checking libpq-fe.h presence... yes
checking for libpq-fe.h... yes
checking for PQserverVersion in -lpq... yes
checking for xml2-config... /usr/bin/xml2-config
checking libxml/tree.h usability... yes
checking libxml/tree.h presence... yes
checking for libxml/tree.h... yes
checking libxml/parser.h usability... yes
checking libxml/parser.h presence... yes
checking for libxml/parser.h... yes
checking libxml/xpath.h usability... yes
checking libxml/xpath.h presence... yes
checking for libxml/xpath.h... yes
checking libxml/xpathInternals.h usability... yes
checking libxml/xpathInternals.h presence... yes
checking for libxml/xpathInternals.h... yes
checking for xmlInitParser in -lxml2... yes
checking for geos-config... /usr/local/bin/geos-config
checking GEOS version... 3.4.2
checking geos_c.h usability... yes
checking geos_c.h presence... yes
checking for geos_c.h... yes
checking for initGEOS in -lgeos_c... yes
checking for sfcgal-config... /usr/local/bin/sfcgal-config
checking whether make sets $(MAKE)... yes
checking for a BSD-compatible install... /usr/bin/install -c
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking whether NLS is requested... yes
checking for msgfmt... no
checking for gmsgfmt... :
checking for xgettext... no
checking for msgmerge... no
checking for ld used by GCC... /usr/bin/ld
checking for shared library run path origin... done
checking for CFPreferencesCopyAppValue... no
checking for CFLocaleCopyCurrent... no
checking for GNU gettext in libc... yes
checking whether to use NLS... yes
checking where the gettext function comes from... libc
checking proj_api.h usability... yes
checking proj_api.h presence... yes
checking for proj_api.h... yes
checking for pj_get_release in -lproj... yes
checking json/json.h usability... no
checking json/json.h presence... no
checking for json/json.h... no
checking for json_object_get in -ljson-c... no
checking for json_object_get in -ljson... no
CPPFLAGS:  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL
TOPOLOGY: Topology support requested
RASTER: Raster support requested
checking for gdal-config... /usr/bin/gdal-config
checking GDAL version... 1.10.0
checking for OGR enabled... yes
checking gdal.h usability... yes
checking gdal.h presence... yes
checking for gdal.h... yes
checking ogr_api.h usability... yes
checking ogr_api.h presence... yes
checking for ogr_api.h... yes
checking cpl_conv.h usability... yes
checking cpl_conv.h presence... yes
checking for cpl_conv.h... yes
checking for library containing GDALAllRegister... none required
checking for library containing OGRRegisterAll... none required
checking for library containing GDALFPolygonize... none required
enabling PostgreSQL extension support...
configure: creating ./config.status
config.status: creating GNUmakefile
config.status: creating extensions/Makefile
config.status: creating extensions/postgis/Makefile
config.status: creating extensions/postgis/postgis.control
config.status: creating extensions/postgis_topology/Makefile
config.status: creating extensions/postgis_topology/postgis_topology.control
config.status: creating extensions/postgis_tiger_geocoder/Makefile
config.status: creating extensions/postgis_tiger_geocoder/postgis_tiger_geocoder.control
config.status: creating liblwgeom/Makefile
config.status: creating liblwgeom/cunit/Makefile
config.status: creating liblwgeom/liblwgeom.h
config.status: creating libpgcommon/Makefile
config.status: creating libpgcommon/cunit/Makefile
config.status: creating postgis/Makefile
config.status: creating postgis/sqldefines.h
config.status: creating loader/Makefile
config.status: creating loader/cunit/Makefile
config.status: creating topology/Makefile
config.status: creating topology/test/Makefile
config.status: creating regress/Makefile
config.status: creating doc/Makefile
config.status: creating doc/Makefile.comments
config.status: creating doc/html/image_src/Makefile
config.status: creating utils/Makefile
config.status: creating java/jdbc/Makefile
config.status: creating raster/Makefile
config.status: creating raster/rt_core/Makefile
config.status: creating raster/rt_pg/Makefile
config.status: creating raster/loader/Makefile
config.status: creating raster/test/Makefile
config.status: creating raster/test/cunit/Makefile
config.status: creating raster/test/regress/Makefile
config.status: creating raster/scripts/Makefile
config.status: creating raster/scripts/python/Makefile
config.status: creating postgis_config.h
config.status: creating raster/raster_config.h
config.status: executing libtool commands
config.status: executing po-directories commands
  PostGIS is now configured for i686-pc-linux-gnu
 -------------- Compiler Info -------------
  C compiler:           gcc -g -O2
  C++ compiler:         g++ -g -O2
  SQL preprocessor:     /usr/bin/cpp -traditional-cpp -P
 -------------- Dependencies --------------
  GEOS config:          /usr/local/bin/geos-config
  GEOS version:         3.4.2
  GDAL config:          /usr/bin/gdal-config
  GDAL version:         1.10.0
  SFCGAL config:        /usr/local/bin/sfcgal-config
  SFCGAL version:       1.0.0
  PostgreSQL config:    /usr/bin/pg_config
  PostgreSQL version:   PostgreSQL 9.3.1
  PROJ4 version:        48
  Libxml2 config:       /usr/bin/xml2-config
  Libxml2 version:      2.8.0
  JSON-C support:       no
  PostGIS debug level:  0
  Perl:                 /usr/bin/perl
 --------------- Extensions ---------------
  PostGIS Raster:       enabled
  PostGIS Topology:     enabled
  SFCGAL support:       enabled
 -------- Documentation Generation --------
  xsltproc:
  xsl style sheets:
  dblatex:
  convert:
  mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
/usr/bin/perl utils/svn_repo_revision.pl
Can't fetch local revision (neither .svn nor .git found)
Not updating existing rev file at 11822
for s in liblwgeom libpgcommon postgis regress raster topology loader utils extensions; do \
		echo "---- Making all in ${s}"; \
		make -C ${s} all || exit 1; \
	done;
---- Making all in liblwgeom
make[1]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/liblwgeom'
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o stringbuffer.lo stringbuffer.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c stringbuffer.c  -fPIC -DPIC -o .libs/stringbuffer.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c stringbuffer.c -o stringbuffer.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o measures.lo measures.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c measures.c  -fPIC -DPIC -o .libs/measures.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c measures.c -o measures.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o measures3d.lo measures3d.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c measures3d.c  -fPIC -DPIC -o .libs/measures3d.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c measures3d.c -o measures3d.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o box2d.lo box2d.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c box2d.c  -fPIC -DPIC -o .libs/box2d.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c box2d.c -o box2d.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o ptarray.lo ptarray.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c ptarray.c  -fPIC -DPIC -o .libs/ptarray.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c ptarray.c -o ptarray.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwgeom_api.lo lwgeom_api.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeom_api.c  -fPIC -DPIC -o .libs/lwgeom_api.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeom_api.c -o lwgeom_api.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwgeom.lo lwgeom.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeom.c  -fPIC -DPIC -o .libs/lwgeom.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeom.c -o lwgeom.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwpoint.lo lwpoint.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwpoint.c  -fPIC -DPIC -o .libs/lwpoint.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwpoint.c -o lwpoint.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwline.lo lwline.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwline.c  -fPIC -DPIC -o .libs/lwline.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwline.c -o lwline.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwpoly.lo lwpoly.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwpoly.c  -fPIC -DPIC -o .libs/lwpoly.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwpoly.c -o lwpoly.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwtriangle.lo lwtriangle.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwtriangle.c  -fPIC -DPIC -o .libs/lwtriangle.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwtriangle.c -o lwtriangle.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwmpoint.lo lwmpoint.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwmpoint.c  -fPIC -DPIC -o .libs/lwmpoint.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwmpoint.c -o lwmpoint.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwmline.lo lwmline.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwmline.c  -fPIC -DPIC -o .libs/lwmline.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwmline.c -o lwmline.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwmpoly.lo lwmpoly.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwmpoly.c  -fPIC -DPIC -o .libs/lwmpoly.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwmpoly.c -o lwmpoly.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwcollection.lo lwcollection.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwcollection.c  -fPIC -DPIC -o .libs/lwcollection.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwcollection.c -o lwcollection.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwcircstring.lo lwcircstring.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwcircstring.c  -fPIC -DPIC -o .libs/lwcircstring.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwcircstring.c -o lwcircstring.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwcompound.lo lwcompound.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwcompound.c  -fPIC -DPIC -o .libs/lwcompound.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwcompound.c -o lwcompound.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwcurvepoly.lo lwcurvepoly.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwcurvepoly.c  -fPIC -DPIC -o .libs/lwcurvepoly.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwcurvepoly.c -o lwcurvepoly.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwmcurve.lo lwmcurve.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwmcurve.c  -fPIC -DPIC -o .libs/lwmcurve.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwmcurve.c -o lwmcurve.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwmsurface.lo lwmsurface.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwmsurface.c  -fPIC -DPIC -o .libs/lwmsurface.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwmsurface.c -o lwmsurface.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwpsurface.lo lwpsurface.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwpsurface.c  -fPIC -DPIC -o .libs/lwpsurface.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwpsurface.c -o lwpsurface.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwtin.lo lwtin.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwtin.c  -fPIC -DPIC -o .libs/lwtin.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwtin.c -o lwtin.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwout_wkb.lo lwout_wkb.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwout_wkb.c  -fPIC -DPIC -o .libs/lwout_wkb.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwout_wkb.c -o lwout_wkb.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwin_geojson.lo lwin_geojson.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwin_geojson.c  -fPIC -DPIC -o .libs/lwin_geojson.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwin_geojson.c -o lwin_geojson.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwin_wkb.lo lwin_wkb.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwin_wkb.c  -fPIC -DPIC -o .libs/lwin_wkb.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwin_wkb.c -o lwin_wkb.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwout_wkt.lo lwout_wkt.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwout_wkt.c  -fPIC -DPIC -o .libs/lwout_wkt.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwout_wkt.c -o lwout_wkt.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwin_wkt_parse.lo lwin_wkt_parse.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwin_wkt_parse.c  -fPIC -DPIC -o .libs/lwin_wkt_parse.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwin_wkt_parse.c -o lwin_wkt_parse.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwin_wkt_lex.lo lwin_wkt_lex.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwin_wkt_lex.c  -fPIC -DPIC -o .libs/lwin_wkt_lex.o
lwin_wkt_lex.c:1418:16: warning: ‘input’ defined but not used [-Wunused-function]
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwin_wkt_lex.c -o lwin_wkt_lex.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwin_wkt.lo lwin_wkt.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwin_wkt.c  -fPIC -DPIC -o .libs/lwin_wkt.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwin_wkt.c -o lwin_wkt.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwutil.lo lwutil.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwutil.c  -fPIC -DPIC -o .libs/lwutil.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwutil.c -o lwutil.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwhomogenize.lo lwhomogenize.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwhomogenize.c  -fPIC -DPIC -o .libs/lwhomogenize.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwhomogenize.c -o lwhomogenize.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwalgorithm.lo lwalgorithm.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwalgorithm.c  -fPIC -DPIC -o .libs/lwalgorithm.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwalgorithm.c -o lwalgorithm.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwsegmentize.lo lwsegmentize.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwsegmentize.c  -fPIC -DPIC -o .libs/lwsegmentize.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwsegmentize.c -o lwsegmentize.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwlinearreferencing.lo lwlinearreferencing.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwlinearreferencing.c  -fPIC -DPIC -o .libs/lwlinearreferencing.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwlinearreferencing.c -o lwlinearreferencing.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwprint.lo lwprint.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwprint.c  -fPIC -DPIC -o .libs/lwprint.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwprint.c -o lwprint.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o vsprintf.lo vsprintf.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c vsprintf.c  -fPIC -DPIC -o .libs/vsprintf.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c vsprintf.c -o vsprintf.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o g_box.lo g_box.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c g_box.c  -fPIC -DPIC -o .libs/g_box.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c g_box.c -o g_box.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o g_serialized.lo g_serialized.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c g_serialized.c  -fPIC -DPIC -o .libs/g_serialized.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c g_serialized.c -o g_serialized.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o g_util.lo g_util.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c g_util.c  -fPIC -DPIC -o .libs/g_util.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c g_util.c -o g_util.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwgeodetic.lo lwgeodetic.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeodetic.c  -fPIC -DPIC -o .libs/lwgeodetic.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeodetic.c -o lwgeodetic.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwgeodetic_tree.lo lwgeodetic_tree.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeodetic_tree.c  -fPIC -DPIC -o .libs/lwgeodetic_tree.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeodetic_tree.c -o lwgeodetic_tree.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwtree.lo lwtree.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwtree.c  -fPIC -DPIC -o .libs/lwtree.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwtree.c -o lwtree.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwout_gml.lo lwout_gml.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwout_gml.c  -fPIC -DPIC -o .libs/lwout_gml.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwout_gml.c -o lwout_gml.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwout_kml.lo lwout_kml.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwout_kml.c  -fPIC -DPIC -o .libs/lwout_kml.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwout_kml.c -o lwout_kml.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwout_geojson.lo lwout_geojson.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwout_geojson.c  -fPIC -DPIC -o .libs/lwout_geojson.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwout_geojson.c -o lwout_geojson.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwout_svg.lo lwout_svg.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwout_svg.c  -fPIC -DPIC -o .libs/lwout_svg.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwout_svg.c -o lwout_svg.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwout_x3d.lo lwout_x3d.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwout_x3d.c  -fPIC -DPIC -o .libs/lwout_x3d.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwout_x3d.c -o lwout_x3d.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwgeom_debug.lo lwgeom_debug.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeom_debug.c  -fPIC -DPIC -o .libs/lwgeom_debug.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeom_debug.c -o lwgeom_debug.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwgeom_geos.lo lwgeom_geos.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeom_geos.c  -fPIC -DPIC -o .libs/lwgeom_geos.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeom_geos.c -o lwgeom_geos.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwgeom_geos_clean.lo lwgeom_geos_clean.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeom_geos_clean.c  -fPIC -DPIC -o .libs/lwgeom_geos_clean.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeom_geos_clean.c -o lwgeom_geos_clean.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwgeom_geos_node.lo lwgeom_geos_node.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeom_geos_node.c  -fPIC -DPIC -o .libs/lwgeom_geos_node.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeom_geos_node.c -o lwgeom_geos_node.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwgeom_geos_split.lo lwgeom_geos_split.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeom_geos_split.c  -fPIC -DPIC -o .libs/lwgeom_geos_split.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeom_geos_split.c -o lwgeom_geos_split.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwgeom_transform.lo lwgeom_transform.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeom_transform.c  -fPIC -DPIC -o .libs/lwgeom_transform.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeom_transform.c -o lwgeom_transform.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -c -o lwgeom_sfcgal.lo lwgeom_sfcgal.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeom_sfcgal.c  -fPIC -DPIC -o .libs/lwgeom_sfcgal.o
lwgeom_sfcgal.c:27:1: warning: no previous prototype for ‘lwgeom_sfcgal_version’ [-Wmissing-prototypes]
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -c lwgeom_sfcgal.c -o lwgeom_sfcgal.o >/dev/null 2>&1
/bin/bash ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I/usr/local/include   -I/usr/local/include -DHAVE_SFCGAL -ffloat-store -c -o lwspheroid.lo lwspheroid.c
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -ffloat-store -c lwspheroid.c  -fPIC -DPIC -o .libs/lwspheroid.o
libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/local/include -I/usr/local/include -DHAVE_SFCGAL -ffloat-store -c lwspheroid.c -o lwspheroid.o >/dev/null 2>&1
/bin/bash ../libtool --tag=CC --mode=link gcc -rpath /usr/local/lib stringbuffer.lo measures.lo measures3d.lo box2d.lo ptarray.lo lwgeom_api.lo lwgeom.lo lwpoint.lo lwline.lo lwpoly.lo lwtriangle.lo lwmpoint.lo lwmline.lo lwmpoly.lo lwcollection.lo lwcircstring.lo lwcompound.lo lwcurvepoly.lo lwmcurve.lo lwmsurface.lo lwpsurface.lo lwtin.lo lwout_wkb.lo lwin_geojson.lo lwin_wkb.lo lwout_wkt.lo lwin_wkt_parse.lo lwin_wkt_lex.lo lwin_wkt.lo lwutil.lo lwhomogenize.lo lwalgorithm.lo lwsegmentize.lo lwlinearreferencing.lo lwprint.lo vsprintf.lo g_box.lo g_serialized.lo g_util.lo lwgeodetic.lo lwgeodetic_tree.lo lwtree.lo lwout_gml.lo lwout_kml.lo lwout_geojson.lo lwout_svg.lo lwout_x3d.lo lwgeom_debug.lo lwgeom_geos.lo lwgeom_geos_clean.lo lwgeom_geos_node.lo lwgeom_geos_split.lo lwgeom_transform.lo lwgeom_sfcgal.lo lwspheroid.lo -release 2.1.0 -L/usr/local/lib -lgeos_c  -lproj  -L/usr/local/lib -lSFCGAL -o liblwgeom.la
*** Warning: Linking the shared library liblwgeom.la against the loadable module
*** libSFCGAL.so is not portable!
libtool: link: gcc -shared  .libs/stringbuffer.o .libs/measures.o .libs/measures3d.o .libs/box2d.o .libs/ptarray.o .libs/lwgeom_api.o .libs/lwgeom.o .libs/lwpoint.o .libs/lwline.o .libs/lwpoly.o .libs/lwtriangle.o .libs/lwmpoint.o .libs/lwmline.o .libs/lwmpoly.o .libs/lwcollection.o .libs/lwcircstring.o .libs/lwcompound.o .libs/lwcurvepoly.o .libs/lwmcurve.o .libs/lwmsurface.o .libs/lwpsurface.o .libs/lwtin.o .libs/lwout_wkb.o .libs/lwin_geojson.o .libs/lwin_wkb.o .libs/lwout_wkt.o .libs/lwin_wkt_parse.o .libs/lwin_wkt_lex.o .libs/lwin_wkt.o .libs/lwutil.o .libs/lwhomogenize.o .libs/lwalgorithm.o .libs/lwsegmentize.o .libs/lwlinearreferencing.o .libs/lwprint.o .libs/vsprintf.o .libs/g_box.o .libs/g_serialized.o .libs/g_util.o .libs/lwgeodetic.o .libs/lwgeodetic_tree.o .libs/lwtree.o .libs/lwout_gml.o .libs/lwout_kml.o .libs/lwout_geojson.o .libs/lwout_svg.o .libs/lwout_x3d.o .libs/lwgeom_debug.o .libs/lwgeom_geos.o .libs/lwgeom_geos_clean.o .libs/lwgeom_geos_node.o .libs/lwgeom_geos_split.o .libs/lwgeom_transform.o .libs/lwgeom_sfcgal.o .libs/lwspheroid.o   -L/usr/local/lib /usr/local/lib/libgeos_c.so /usr/lib/libproj.so /usr/local/lib/libSFCGAL.so    -Wl,-soname -Wl,liblwgeom-2.1.0.so -o .libs/liblwgeom-2.1.0.so
libtool: link: (cd ".libs" && rm -f "liblwgeom.so" && ln -s "liblwgeom-2.1.0.so" "liblwgeom.so")
libtool: link: ar cru .libs/liblwgeom.a  stringbuffer.o measures.o measures3d.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o lwline.o lwpoly.o lwtriangle.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o lwcircstring.o lwcompound.o lwcurvepoly.o lwmcurve.o lwmsurface.o lwpsurface.o lwtin.o lwout_wkb.o lwin_geojson.o lwin_wkb.o lwout_wkt.o lwin_wkt_parse.o lwin_wkt_lex.o lwin_wkt.o lwutil.o lwhomogenize.o lwalgorithm.o lwsegmentize.o lwlinearreferencing.o lwprint.o vsprintf.o g_box.o g_serialized.o g_util.o lwgeodetic.o lwgeodetic_tree.o lwtree.o lwout_gml.o lwout_kml.o lwout_geojson.o lwout_svg.o lwout_x3d.o lwgeom_debug.o lwgeom_geos.o lwgeom_geos_clean.o lwgeom_geos_node.o lwgeom_geos_split.o lwgeom_transform.o lwgeom_sfcgal.o lwspheroid.o
libtool: link: ranlib .libs/liblwgeom.a
libtool: link: ( cd ".libs" && rm -f "liblwgeom.la" && ln -s "../liblwgeom.la" "liblwgeom.la" )
make[1]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/liblwgeom'
---- Making all in libpgcommon
make[1]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/libpgcommon'
gcc -g -O2 -I../liblwgeom -I/usr/include/postgresql/9.3/server   -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o gserialized_gist.o gserialized_gist.c
gcc -g -O2 -I../liblwgeom -I/usr/include/postgresql/9.3/server   -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwgeom_transform.o lwgeom_transform.c
gcc -g -O2 -I../liblwgeom -I/usr/include/postgresql/9.3/server   -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwgeom_cache.o lwgeom_cache.c
gcc -g -O2 -I../liblwgeom -I/usr/include/postgresql/9.3/server   -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwgeom_pg.o lwgeom_pg.c
ar rs libpgcommon.a gserialized_gist.o lwgeom_transform.o lwgeom_cache.o lwgeom_pg.o
ar: creating libpgcommon.a
make[1]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/libpgcommon'
---- Making all in postgis
make[1]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/postgis'
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o postgis_module.o postgis_module.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_accum.o lwgeom_accum.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_spheroid.o lwgeom_spheroid.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_ogc.o lwgeom_ogc.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_functions_analytic.o lwgeom_functions_analytic.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_inout.o lwgeom_inout.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_functions_basic.o lwgeom_functions_basic.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_btree.o lwgeom_btree.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_box.o lwgeom_box.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_box3d.o lwgeom_box3d.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_geos.o lwgeom_geos.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_sfcgal.o lwgeom_sfcgal.c
In file included from ../libpgcommon/lwgeom_pg.h:23:0,
                 from lwgeom_sfcgal.c:19:
../libpgcommon/pgsql_compat.h:16:0: warning: "SET_VARSIZE" redefined [enabled by default]
/usr/include/postgresql/9.3/server/postgres.h:260:0: note: this is the location of the previous definition
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_backend_api.o lwgeom_backend_api.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_geos_prepared.o lwgeom_geos_prepared.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_geos_clean.o lwgeom_geos_clean.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_geos_relatematch.o lwgeom_geos_relatematch.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_export.o lwgeom_export.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_in_gml.o lwgeom_in_gml.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_in_kml.o lwgeom_in_kml.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_in_geohash.o lwgeom_in_geohash.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_in_geojson.o lwgeom_in_geojson.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_triggers.o lwgeom_triggers.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_dump.o lwgeom_dump.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_dumppoints.o lwgeom_dumppoints.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_functions_lrs.o lwgeom_functions_lrs.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o long_xact.o long_xact.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_sqlmm.o lwgeom_sqlmm.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_rtree.o lwgeom_rtree.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o lwgeom_transform.o lwgeom_transform.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o gserialized_typmod.o gserialized_typmod.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o gserialized_gist_2d.o gserialized_gist_2d.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o gserialized_gist_nd.o gserialized_gist_nd.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o gserialized_estimate.o gserialized_estimate.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o geography_inout.o geography_inout.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o geography_btree.o geography_btree.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o geography_measurement.o geography_measurement.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o geography_measurement_trees.o geography_measurement_trees.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I../liblwgeom -I../libpgcommon  -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  -fPIC -I/usr/local/include -DHAVE_SFCGAL -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o geometry_inout.o geometry_inout.c
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -shared -o postgis-2.1.so postgis_module.o lwgeom_accum.o lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_inout.o lwgeom_functions_basic.o lwgeom_btree.o lwgeom_box.o lwgeom_box3d.o lwgeom_geos.o lwgeom_sfcgal.o lwgeom_backend_api.o lwgeom_geos_prepared.o lwgeom_geos_clean.o lwgeom_geos_relatematch.o lwgeom_export.o lwgeom_in_gml.o lwgeom_in_kml.o lwgeom_in_geohash.o lwgeom_in_geojson.o lwgeom_triggers.o lwgeom_dump.o lwgeom_dumppoints.o lwgeom_functions_lrs.o long_xact.o lwgeom_sqlmm.o lwgeom_rtree.o lwgeom_transform.o gserialized_typmod.o gserialized_gist_2d.o gserialized_gist_nd.o gserialized_estimate.o geography_inout.o geography_btree.o geography_measurement.o geography_measurement_trees.o geometry_inout.o -L/usr/lib -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-z,now -Wl,--as-needed -L/usr/lib/mit-krb5 -L/usr/lib/i386-linux-gnu/mit-krb5 -L/usr/lib/i386-linux-gnu  -Wl,--as-needed  ../libpgcommon/libpgcommon.a ../liblwgeom/.libs/liblwgeom.a  -L/usr/local/lib  -lgeos_c -lproj  -L/usr/lib -lxml2 -L/usr/local/lib -lSFCGAL -L/usr/local/lib -lSFCGAL
/usr/bin/cpp -traditional-cpp -P -I../libpgcommon postgis.sql.in | grep -v '^#' | \
	/usr/bin/perl -lpe "s'MODULE_PATHNAME'\$libdir/postgis-2.1'g" > postgis.sql
/usr/bin/perl ../utils/create_undef.pl postgis.sql 93 > uninstall_postgis.sql
cat postgis_drop_before.sql postgis.sql postgis_drop_after.sql > postgis_upgrade_20_21.sql.in
/usr/bin/perl ../utils/postgis_proc_upgrade.pl postgis_upgrade_20_21.sql.in 2.0 > postgis_upgrade_20_21.sql
cp postgis_upgrade_20_21.sql postgis_upgrade_21_minor.sql
/usr/bin/cpp -traditional-cpp -P -I../libpgcommon legacy.sql.in | grep -v '^#' | \
	/usr/bin/perl -lpe "s'MODULE_PATHNAME'\$libdir/postgis-2.1'g" > legacy.sql
/usr/bin/perl ../utils/create_undef.pl legacy.sql 93 > uninstall_legacy.sql
/usr/bin/cpp -traditional-cpp -P -I../libpgcommon legacy_minimal.sql.in | grep -v '^#' | \
	/usr/bin/perl -lpe "s'MODULE_PATHNAME'\$libdir/postgis-2.1'g" > legacy_minimal.sql
/usr/bin/cpp -traditional-cpp -P -I../libpgcommon legacy_gist.sql.in | grep -v '^#' | \
	/usr/bin/perl -lpe "s'MODULE_PATHNAME'\$libdir/postgis-2.1'g" > legacy_gist.sql
/usr/bin/cpp -traditional-cpp -P -I../libpgcommon sfcgal.sql.in | grep -v '^#' | \
	/usr/bin/perl -lpe "s'MODULE_PATHNAME'\$libdir/postgis-2.1'g" > sfcgal.sql
/usr/bin/perl ../utils/create_undef.pl sfcgal.sql 93 > uninstall_sfcgal.sql
make[1]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/postgis'
---- Making all in regress
make[1]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/regress'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/regress'
---- Making all in raster
make[1]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/raster'
make -C rt_core
make[2]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/raster/rt_core'
gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I../../liblwgeom -I/usr/include/gdal  -I/usr/local/include   -c -o rt_api.o rt_api.c
ar rs librtcore.a rt_api.o
ar: creating librtcore.a
make[2]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/raster/rt_core'
make -C rt_pg
make[2]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/raster/rt_pg'
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -I/usr/local/include  -I/usr/include/libxml2 -I/usr/local/include -DHAVE_SFCGAL  "-I../../liblwgeom" -I/usr/include/gdal "-I../../libpgcommon"  -I../rt_core -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o rt_pg.o rt_pg.c
rt_pg.c: In function ‘rt_pg_error’:
rt_pg.c:19155:5: warning: function might be possible candidate for ‘gnu_printf’ format attribute [-Wmissing-format-attribute]
gcc -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -fpic -shared -o rtpostgis-2.1.so rt_pg.o -L/usr/lib -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-z,now -Wl,--as-needed -L/usr/lib/mit-krb5 -L/usr/lib/i386-linux-gnu/mit-krb5 -L/usr/lib/i386-linux-gnu  -Wl,--as-needed  ../rt_core/librtcore.a ../../liblwgeom/.libs/liblwgeom.a ../../libpgcommon/libpgcommon.a -L/usr/lib -lgdal  -L/usr/local/lib  -lgeos_c -lproj  -L/usr/lib -lxml2 -L/usr/local/lib -lSFCGAL
/usr/bin/cpp -traditional-cpp -P -I../../postgis/ -I../../ rtpostgis.sql.in | grep -v '^#' | \
	/usr/bin/perl -lpe "s'MODULE_PATHNAME'\$libdir/rtpostgis-2.1'g" > rtpostgis.sql
/usr/bin/cpp -traditional-cpp -P -I../../postgis/ -I../../ rtpostgis_upgrade_cleanup.sql.in | grep -v '^#' | \
	/usr/bin/perl -lpe "s'MODULE_PATHNAME'\$libdir/rtpostgis-2.1'g" > rtpostgis_upgrade_cleanup.sql
/usr/bin/cpp -traditional-cpp -P -I../../postgis/ -I../../ rtpostgis_drop.sql.in | grep -v '^#' | \
	/usr/bin/perl -lpe "s'MODULE_PATHNAME'\$libdir/rtpostgis-2.1'g" > rtpostgis_drop.sql
/usr/bin/perl -0777 -ne 's/^(CREATE|ALTER) (CAST|OPERATOR|TYPE|TABLE|SCHEMA|DOMAIN|TRIGGER).*?;//msg;print;' rtpostgis.sql > rtpostgis_upgrade.sql
cat rtpostgis_upgrade_cleanup.sql rtpostgis_drop.sql rtpostgis_upgrade.sql > rtpostgis_upgrade_20_21.sql
cat rtpostgis_upgrade_cleanup.sql rtpostgis_drop.sql rtpostgis_upgrade.sql > rtpostgis_upgrade_21_minor.sql
/usr/bin/perl ../../utils/create_undef.pl rtpostgis.sql 93 > uninstall_rtpostgis.sql
/usr/bin/cpp -traditional-cpp -P -I../../postgis/ -I../../ rtpostgis_legacy.sql.in | grep -v '^#' | \
	/usr/bin/perl -lpe "s'MODULE_PATHNAME'\$libdir/rtpostgis-2.1'g" > rtpostgis_legacy.sql
make[2]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/raster/rt_pg'
make -C loader
make[2]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/raster/loader'
gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I../rt_core -I../../liblwgeom  -I/usr/include/gdal -I/usr/local/include   -c raster2pgsql.c
/bin/bash ../../libtool --mode=link gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes -I../rt_core -I../../liblwgeom  -I/usr/include/gdal -I/usr/local/include   ../rt_core/librtcore.a raster2pgsql.o ../../liblwgeom/liblwgeom.la -L/usr/lib -lgdal  -L/usr/local/lib -lgeos_c  -lc -lm -o raster2pgsql
libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I../rt_core -I../../liblwgeom -I/usr/include/gdal -I/usr/local/include raster2pgsql.o -o .libs/raster2pgsql  ../rt_core/librtcore.a ../../liblwgeom/.libs/liblwgeom.so -L/usr/lib -lgdal -L/usr/local/lib /usr/local/lib/libgeos_c.so -lc -lm
make[2]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/raster/loader'
make -C rt_pg rtpostgis.sql
make[2]: `rtpostgis.sql' is up to date.
make[1]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/raster'
---- Making all in topology
make[1]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/topology'
/usr/bin/cpp -traditional-cpp -P topology.sql.in | grep -v '^#' > topology.sql
/usr/bin/cpp -traditional-cpp -P topology_drop_before.sql.in | grep -v '^#' > topology_drop_before.sql
/usr/bin/perl -0777 -ne 's/^(CREATE|ALTER) (CAST|OPERATOR|TYPE|TABLE|SCHEMA|DOMAIN|TRIGGER).*?;//msg;print;' topology.sql > topology_upgrade.sql
/usr/bin/cpp -traditional-cpp -P topology_drop_after.sql.in | grep -v '^#' > topology_drop_after.sql
cat topology_drop_before.sql topology_upgrade.sql topology_drop_after.sql > topology_upgrade_21_minor.sql
/usr/bin/perl ../utils/create_undef.pl topology.sql 93 > uninstall_topology.sql
make[1]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/topology'
---- Making all in loader
make[1]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/loader'
gcc -I ../liblwgeom -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes    -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o shpopen.o shpopen.c
gcc -I ../liblwgeom -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes    -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o dbfopen.o dbfopen.c
gcc -I ../liblwgeom -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes    -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o getopt.o getopt.c
getopt.c: In function ‘pgis_getopt’:
getopt.c:71:3: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
getopt.c:85:4: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
gcc -I ../liblwgeom -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes    -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o shpcommon.o shpcommon.c
gcc -I ../liblwgeom -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes    -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o safileio.o safileio.c
gcc -I ../liblwgeom -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes    -c shp2pgsql-core.c
gcc -I ../liblwgeom -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes    -I. -I./ -I/usr/include/postgresql/9.3/server -I/usr/include/postgresql/internal -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o shp2pgsql-cli.o shp2pgsql-cli.c
/bin/bash ../libtool --mode=link \
	  gcc -I ../liblwgeom -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes    shpopen.o dbfopen.o getopt.o shpcommon.o safileio.o shp2pgsql-core.o shp2pgsql-cli.o ../liblwgeom/liblwgeom.la -o shp2pgsql  -lc
libtool: link: gcc -I ../liblwgeom -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes shpopen.o dbfopen.o getopt.o shpcommon.o safileio.o shp2pgsql-core.o shp2pgsql-cli.o -o .libs/shp2pgsql  ../liblwgeom/.libs/liblwgeom.so -lc
gcc -I ../liblwgeom -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes    -I/usr/include/postgresql -c pgsql2shp-core.c
pgsql2shp-core.c: In function ‘projFileCreate’:
pgsql2shp-core.c:710:9: warning: variable ‘result’ set but not used [-Wunused-but-set-variable]
gcc -I ../liblwgeom -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes    -I/usr/include/postgresql -c pgsql2shp-cli.c
	  gcc -I ../liblwgeom -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes    shpopen.o dbfopen.o getopt.o shpcommon.o safileio.o pgsql2shp-core.o pgsql2shp-cli.o ../liblwgeom/liblwgeom.la -lc -L/usr/lib -lpq  -o pgsql2shp
libtool: link: gcc -I ../liblwgeom -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes shpopen.o dbfopen.o getopt.o shpcommon.o safileio.o pgsql2shp-core.o pgsql2shp-cli.o -o .libs/pgsql2shp  ../liblwgeom/.libs/liblwgeom.so -lc -L/usr/lib -lpq
make[1]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/loader'
---- Making all in utils
make[1]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/utils'
Makefile:54: warning: overriding commands for target `uninstall'
/usr/lib/postgresql/9.3/lib/pgxs/src/makefiles/pgxs.mk:199: warning: ignoring old commands for target `uninstall'
Makefile:60: warning: overriding commands for target `clean'
/usr/lib/postgresql/9.3/lib/pgxs/src/makefiles/pgxs.mk:230: warning: ignoring old commands for target `clean'
sed 's, at SRID_MAXIMUM@,999999,g;s, at SRID_USER_MAXIMUM@,998999,' postgis_restore.pl.in >postgis_restore.pl
chmod +x postgis_restore.pl create_undef.pl svn_repo_revision.pl postgis_proc_upgrade.pl profile_intersects.pl test_estimation.pl test_joinestimation.pl
make[1]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/utils'
---- Making all in extensions
make[1]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/extensions'
for DIR in postgis  postgis_tiger_geocoder  postgis_topology; do \
		echo "---- Making all in ${DIR}"; \
		make -C "${DIR}" all; \
	done
make[2]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/extensions/postgis'
sed -e 's/BEGIN;//g' -e 's/COMMIT;//g'  ../../postgis/postgis.sql > sql_bits/postgis.sql
cp ../../doc/postgis_comments.sql sql_bits/postgis_comments.sql
sed -e 's/BEGIN;//g' -e 's/COMMIT;//g'  ../../raster/rt_pg/rtpostgis.sql > sql_bits/rtpostgis.sql
cp ../../doc/raster_comments.sql sql_bits/raster_comments.sql
sed -e 's/BEGIN;//g' -e 's/COMMIT;//g'  ../../spatial_ref_sys.sql > sql_bits/spatial_ref_sys.sql
mkdir -p sql
cat sql_bits/postgis.sql sql_bits/postgis_comments.sql sql_bits/rtpostgis.sql sql_bits/mark_editable_objects.sql.in sql_bits/raster_comments.sql sql_bits/spatial_ref_sys.sql > sql/postgis.sql
mkdir -p sql
cp sql/postgis.sql sql/postgis--2.1.0.sql
mkdir -p sql
cp sql_bits/postgis--unpackaged.sql.in sql/postgis--unpackaged--2.1.0.sql
sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' \
		 -e '/^\(DROP\|CREATE\) \(CAST\).*;/d' \
		 -e '/^\(DROP\|CREATE\) \(CAST\)/,/\;/d' \
		 -e 's/DROP FUNCTION postgis_major_version_check();/ALTER EXTENSION postgis DROP FUNCTION postgis_major_version_check();DROP FUNCTION postgis_major_version_check();/g' \
	 	 ../../postgis/postgis_upgrade_20_21.sql > sql_bits/postgis_upgrade_20_21.sql
		-e 's/DROP FUNCTION _rename_raster_tables();/ALTER EXTENSION postgis DROP FUNCTION _rename_raster_tables();DROP FUNCTION _rename_raster_tables();/g' \
		-e 's/DROP FUNCTION _drop_st_samealignment();/ALTER EXTENSION postgis DROP FUNCTION _drop_st_samealignment();DROP FUNCTION _drop_st_samealignment();/g' \
		-e 's/DROP CAST\(.*\)/SELECT postgis_extension_drop_if_exists('\''postgis'\'', '\''DROP CAST \1'\'');DROP CAST \1/' \
	../../raster/rt_pg/rtpostgis_upgrade_20_21.sql > sql_bits/rtpostgis_upgrade_20_21.sql
cat ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql_bits/postgis_upgrade_20_21.sql sql_bits/rtpostgis_upgrade_20_21.sql ../../doc/raster_comments.sql ../../doc/postgis_comments.sql ../postgis_extension_helper_uninstall.sql > sql_bits/postgis_raster_upgrade_minor.sql
cp sql_bits/postgis_raster_upgrade_minor.sql sql/postgis--2.1.0--2.1.0next.sql
cp sql_bits/postgis_raster_upgrade_minor.sql sql/postgis--2.1.0next--2.1.0.sql
for OLD_VERSION in 2.0.0 2.0.1 2.0.2 2.0.3 2.0.4 2.1.0rc1 2.1.0rc2 2.1.0rc3; do \
  	  cat sql_bits/postgis_raster_upgrade_minor.sql > sql/postgis--$OLD_VERSION--2.1.0.sql; \
	done
make[2]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/extensions/postgis'
---- Making all in postgis_tiger_geocoder
make[2]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/extensions/postgis_tiger_geocoder'
sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' -e '/^CREATE SCHEMA/d;'  sql_bits/tiger_geocoder.sql.in > sql_bits/tiger_geocoder.sql
cp ../../doc/tiger_geocoder_comments.sql sql_bits/tiger_geocoder_comments.sql
cat sql_bits/tiger_geocoder.sql sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql > sql/postgis_tiger_geocoder.sql
cp sql/postgis_tiger_geocoder.sql sql/postgis_tiger_geocoder--2.1.0.sql
cp sql_bits/tiger_geocoder--unpackaged.sql.in sql/postgis_tiger_geocoder--unpackaged--2.1.0.sql
sed -e '/^\(CREATE\|ALTER\) \(CAST\|TYPE\|TABLE\|SCHEMA\|DOMAIN\|TRIGGER\).*;/d' \
	 	 -e '/^\(CREATE\|ALTER\) \(CAST\|TYPE\|TABLE\|SCHEMA\|DOMAIN\|TRIGGER\)/,/\;/d' \
	 	 sql_bits/tiger_geocoder_minor.sql.in > sql/tiger_geocoder_upgrade_minor.sql
cat ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/tiger_geocoder_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql ../postgis_extension_helper_uninstall.sql > sql/postgis_tiger_geocoder--2.1.0--2.1.0next.sql
cp sql/postgis_tiger_geocoder--2.1.0--2.1.0next.sql sql/postgis_tiger_geocoder--2.1.0next--2.1.0.sql
  	  cat ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/tiger_geocoder_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql ../postgis_extension_helper_uninstall.sql > sql/postgis_tiger_geocoder--$OLD_VERSION--2.1.0.sql; \
	done
make[2]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/extensions/postgis_tiger_geocoder'
---- Making all in postgis_topology
make[2]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/extensions/postgis_topology'
sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' -e '/^CREATE SCHEMA/d;'  ../../topology/topology.sql > sql_bits/topology.sql
cp ../../doc/topology_comments.sql sql_bits/topology_comments.sql
mkdir -p sql
cat sql_bits/topology.sql sql_bits/mark_editable_objects.sql.in sql_bits/topology_comments.sql > sql/postgis_topology.sql
mkdir -p sql
cp sql/postgis_topology.sql sql/postgis_topology--2.1.0.sql
mkdir -p sql
cp sql_bits/topology--unpackaged.sql.in sql/postgis_topology--unpackaged--2.1.0.sql
sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' -e '/^CREATE SCHEMA/d;'  ../../topology/topology_upgrade_21_minor.sql > sql/topology_upgrade_minor.sql
cat ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/topology_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in sql_bits/topology_comments.sql ../postgis_extension_helper_uninstall.sql > sql/postgis_topology--2.1.0--2.1.0next.sql
cat ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/topology_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in sql_bits/topology_comments.sql ../postgis_extension_helper_uninstall.sql > sql/postgis_topology--2.1.0next--2.1.0.sql
  	  cat ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/topology_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in sql_bits/topology_comments.sql ../postgis_extension_helper_uninstall.sql > sql/postgis_topology--$OLD_VERSION--2.1.0.sql; \
	done
make[2]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/extensions/postgis_topology'
make[1]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/extensions'
PostGIS was built successfully. Ready to install.
/usr/bin/perl utils/svn_repo_revision.pl
Can't fetch local revision (neither .svn nor .git found)
Not updating existing rev file at 11822
for s in liblwgeom libpgcommon postgis regress raster topology loader utils extensions; do \
		echo "---- Making all in ${s}"; \
		make -C ${s} all || exit 1; \
	done;
---- Making all in liblwgeom
make[1]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/liblwgeom'
make -C rt_core
make[2]: Nothing to be done for `all'.
make -C rt_pg
make -C loader
	done
	done
	done
	done
make -C doc comments-install
make[1]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/doc'
if test -e postgis_comments.sql  -a \
	        -e raster_comments.sql   -a \
	        -e topology_comments.sql -a \
	        -e sfcgal_comments.sql -a \
	        -e tiger_geocoder_comments.sql; then \
	  make -f Makefile.comments install; \
	fi
make[2]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/doc'
/bin/mkdir -p '/usr/share/postgresql/9.3/contrib/postgis-2.1'
/usr/bin/install -c -m 644 postgis_comments.sql raster_comments.sql topology_comments.sql '/usr/share/postgresql/9.3/contrib/postgis-2.1/'
make[2]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/doc'
make[1]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/doc'
		echo "---- Making install in ${s}"; \
		make -C ${s} install || exit 1; \
	done;
---- Making install in liblwgeom
/bin/bash ../libtool --mode=install /bin/bash ../install-sh liblwgeom.la "/usr/local/lib/liblwgeom.la"
libtool: install: /bin/bash ../install-sh .libs/liblwgeom-2.1.0.so /usr/local/lib/liblwgeom-2.1.0.so
libtool: install: (cd /usr/local/lib && { ln -s -f liblwgeom-2.1.0.so liblwgeom.so || { rm -f liblwgeom.so && ln -s liblwgeom-2.1.0.so liblwgeom.so; }; })
libtool: install: /bin/bash ../install-sh .libs/liblwgeom.lai /usr/local/lib/liblwgeom.la
libtool: install: /bin/bash ../install-sh .libs/liblwgeom.a /usr/local/lib/liblwgeom.a
libtool: install: chmod 644 /usr/local/lib/liblwgeom.a
libtool: install: ranlib /usr/local/lib/liblwgeom.a
libtool: finish: PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/sbin" ldconfig -n /usr/local/lib
Libraries have been installed in:
   /usr/local/lib
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
   - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
     during execution
   - add LIBDIR to the `LD_RUN_PATH' environment variable
     during linking
   - use the `-Wl,-rpath -Wl,LIBDIR' linker flag
   - have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
/bin/bash ../install-sh liblwgeom.h "/usr/local/include/liblwgeom.h"
---- Making install in libpgcommon
make[1]: Nothing to be done for `install'.
---- Making install in postgis
/bin/mkdir -p '/usr/lib/postgresql/9.3/lib'
/usr/bin/install -c -m 755  postgis-2.1.so '/usr/lib/postgresql/9.3/lib/postgis-2.1.so'
/usr/bin/install -c -m 644 ../spatial_ref_sys.sql postgis.sql uninstall_postgis.sql postgis_upgrade_20_21.sql postgis_upgrade_21_minor.sql legacy.sql uninstall_legacy.sql legacy_minimal.sql legacy_gist.sql uninstall_sfcgal.sql sfcgal.sql '/usr/share/postgresql/9.3/contrib/postgis-2.1/'
---- Making install in regress
---- Making install in raster
make -C rt_core
make -C rt_pg
make -C loader
make -C rt_pg install
/usr/bin/install -c -m 755  rtpostgis-2.1.so '/usr/lib/postgresql/9.3/lib/rtpostgis-2.1.so'
/usr/bin/install -c -m 644 rtpostgis.sql rtpostgis_upgrade_20_21.sql rtpostgis_upgrade_21_minor.sql uninstall_rtpostgis.sql rtpostgis_legacy.sql '/usr/share/postgresql/9.3/contrib/postgis-2.1/'
make -C loader install
/bin/bash ../../libtool --mode=install /bin/bash ../../install-sh raster2pgsql "/usr/lib/postgresql/9.3/bin/raster2pgsql"
libtool: install: /bin/bash ../../install-sh .libs/raster2pgsql /usr/lib/postgresql/9.3/bin/raster2pgsql
make -C scripts install
make[2]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/raster/scripts'
make -C python
make[3]: Entering directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/raster/scripts/python'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/raster/scripts/python'
make[2]: Leaving directory `/home/remi/Logiciels_dl/postgis_2_1/postgis-2.1.0/raster/scripts'
---- Making install in topology
/usr/bin/install -c -m 644 topology.sql topology_upgrade_21_minor.sql uninstall_topology.sql '/usr/share/postgresql/9.3/contrib/postgis-2.1/'
---- Making install in loader
/bin/bash ../libtool --mode=install /bin/bash ../install-sh pgsql2shp "/usr/lib/postgresql/9.3/bin/pgsql2shp"
libtool: install: /bin/bash ../install-sh .libs/pgsql2shp /usr/lib/postgresql/9.3/bin/pgsql2shp
/bin/bash ../libtool --mode=install /bin/bash ../install-sh shp2pgsql "/usr/lib/postgresql/9.3/bin/shp2pgsql"
libtool: install: /bin/bash ../install-sh .libs/shp2pgsql /usr/lib/postgresql/9.3/bin/shp2pgsql
---- Making install in utils
/bin/bash ../install-sh -m 644 postgis_restore.pl '/usr/share/postgresql/9.3/contrib/postgis-2.1/'
mode=install /bin/bash ../install-sh postgis_restore.pl "/usr/share/postgresql/9.3/contrib/postgis-2.1/postgis_restore.pl"
---- Making install in extensions
		echo "---- Making install in ${DIR}"; \
		make -C "${DIR}" install; \
	done
	done
/bin/mkdir -p '/usr/share/postgresql/9.3/extension'
/usr/bin/install -c -m 644 postgis.control '/usr/share/postgresql/9.3/extension/'
/usr/bin/install -c -m 644 sql/postgis--2.0.0--2.1.0.sql sql/postgis--2.0.1--2.1.0.sql sql/postgis--2.0.2--2.1.0.sql sql/postgis--2.0.3--2.1.0.sql sql/postgis--2.0.4--2.1.0.sql sql/postgis--2.1.0--2.1.0next.sql sql/postgis--2.1.0next--2.1.0.sql sql/postgis--2.1.0rc1--2.1.0.sql sql/postgis--2.1.0rc2--2.1.0.sql sql/postgis--2.1.0rc3--2.1.0.sql sql/postgis--2.1.0.sql sql/postgis--unpackaged--2.1.0.sql '/usr/share/postgresql/9.3/extension/'
---- Making install in postgis_tiger_geocoder
	done
/usr/bin/install -c -m 644 postgis_tiger_geocoder.control '/usr/share/postgresql/9.3/extension/'
/usr/bin/install -c -m 644 sql/postgis_tiger_geocoder--2.0.0--2.1.0.sql sql/postgis_tiger_geocoder--2.0.1--2.1.0.sql sql/postgis_tiger_geocoder--2.0.2--2.1.0.sql sql/postgis_tiger_geocoder--2.0.3--2.1.0.sql sql/postgis_tiger_geocoder--2.0.4--2.1.0.sql sql/postgis_tiger_geocoder--2.1.0--2.1.0next.sql sql/postgis_tiger_geocoder--2.1.0next--2.1.0.sql sql/postgis_tiger_geocoder--2.1.0rc1--2.1.0.sql sql/postgis_tiger_geocoder--2.1.0rc2--2.1.0.sql sql/postgis_tiger_geocoder--2.1.0rc3--2.1.0.sql sql/postgis_tiger_geocoder--2.1.0.sql sql/postgis_tiger_geocoder--unpackaged--2.1.0.sql '/usr/share/postgresql/9.3/extension/'
---- Making install in postgis_topology
	done
/usr/bin/install -c -m 644 postgis_topology.control '/usr/share/postgresql/9.3/extension/'
/usr/bin/install -c -m 644 sql/postgis_topology--2.0.0--2.1.0.sql sql/postgis_topology--2.0.1--2.1.0.sql sql/postgis_topology--2.0.2--2.1.0.sql sql/postgis_topology--2.0.3--2.1.0.sql sql/postgis_topology--2.0.4--2.1.0.sql sql/postgis_topology--2.1.0--2.1.0next.sql sql/postgis_topology--2.1.0next--2.1.0.sql sql/postgis_topology--2.1.0rc1--2.1.0.sql sql/postgis_topology--2.1.0rc2--2.1.0.sql sql/postgis_topology--2.1.0rc3--2.1.0.sql sql/postgis_topology--2.1.0.sql sql/postgis_topology--unpackaged--2.1.0.sql '/usr/share/postgresql/9.3/extension/'
sudo make install
[sudo] password for remi:
[100%] Built target SFCGAL
Install the project...
-- Install configuration: "Release"
-- Installing: /usr/local/./include
-- Installing: /usr/local/./include/SFCGAL
-- Installing: /usr/local/./include/SFCGAL/capi
-- Up-to-date: /usr/local/./include/SFCGAL/capi/sfcgal_c.h
-- Up-to-date: /usr/local/./include/SFCGAL/Surface.h
-- Up-to-date: /usr/local/./include/SFCGAL/MultiSolid.h
-- Up-to-date: /usr/local/./include/SFCGAL/version.h.cmake
-- Up-to-date: /usr/local/./include/SFCGAL/MultiLineString.h
-- Up-to-date: /usr/local/./include/SFCGAL/export.h
-- Installing: /usr/local/./include/SFCGAL/algorithm
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/orientation.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/intersects.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/distance.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/normal.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/distance3d.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/volume.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/offset.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/straightSkeleton.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/collectionToMulti.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/BoundaryVisitor.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/ConsistentOrientationBuilder.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/difference.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/collect.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/collectionHomogenize.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/length.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/intersection.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/minkowskiSum.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/convexHull.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/connection.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/plane.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/extrude.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/tesselate.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/force2D.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/collectionExtract.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/isValid.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/area.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/translate.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/force3D.h
-- Up-to-date: /usr/local/./include/SFCGAL/algorithm/covers.h
-- Up-to-date: /usr/local/./include/SFCGAL/LineString.h
-- Up-to-date: /usr/local/./include/SFCGAL/MultiPolygon.h
-- Up-to-date: /usr/local/./include/SFCGAL/Grid.h
-- Up-to-date: /usr/local/./include/SFCGAL/Geometry.h
-- Up-to-date: /usr/local/./include/SFCGAL/GeometryCollection.h
-- Up-to-date: /usr/local/./include/SFCGAL/Exception.h
-- Up-to-date: /usr/local/./include/SFCGAL/numeric.h
-- Up-to-date: /usr/local/./include/SFCGAL/Validity.h
-- Up-to-date: /usr/local/./include/SFCGAL/GeometryVisitor.h
-- Installing: /usr/local/./include/SFCGAL/io
-- Up-to-date: /usr/local/./include/SFCGAL/io/asc.h
-- Up-to-date: /usr/local/./include/SFCGAL/io/GeometryStreams.h
-- Up-to-date: /usr/local/./include/SFCGAL/io/osg.h
-- Up-to-date: /usr/local/./include/SFCGAL/io/ewkt.h
-- Up-to-date: /usr/local/./include/SFCGAL/io/vtk.h
-- Up-to-date: /usr/local/./include/SFCGAL/io/wkt.h
-- Up-to-date: /usr/local/./include/SFCGAL/config.h
-- Up-to-date: /usr/local/./include/SFCGAL/Point.h
-- Up-to-date: /usr/local/./include/SFCGAL/MultiPoint.h
-- Up-to-date: /usr/local/./include/SFCGAL/Kernel.h
-- Up-to-date: /usr/local/./include/SFCGAL/Envelope.h
-- Installing: /usr/local/./include/SFCGAL/detail
-- Up-to-date: /usr/local/./include/SFCGAL/detail/polygonSetToMultiPolygon.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/TypeForDimension.h
-- Installing: /usr/local/./include/SFCGAL/detail/algorithm
-- Up-to-date: /usr/local/./include/SFCGAL/detail/algorithm/coversPoints.h
-- Installing: /usr/local/./include/SFCGAL/detail/graph
-- Installing: /usr/local/./include/SFCGAL/detail/graph/algorithm
-- Up-to-date: /usr/local/./include/SFCGAL/detail/graph/algorithm/orientation.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/graph/algorithm/isHalfEdge.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/graph/Edge.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/graph/GeometryGraph.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/graph/GeometryGraphBuilder.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/graph/Vertex.h
-- Installing: /usr/local/./include/SFCGAL/detail/tools
-- Up-to-date: /usr/local/./include/SFCGAL/detail/tools/InputStreamReader.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/tools/CharArrayBuffer.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/tools/Registry.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/tools/Log.h
-- Installing: /usr/local/./include/SFCGAL/detail/transform
-- Up-to-date: /usr/local/./include/SFCGAL/detail/transform/ForceZOrderPoints.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/transform/ForceOrderPoints.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/transform/RoundTransform.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/transform/AffineTransform2.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/transform/AffineTransform3.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/transform/Force2D.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/transform/ForceZ.h
-- Installing: /usr/local/./include/SFCGAL/detail/io
-- Up-to-date: /usr/local/./include/SFCGAL/detail/io/WktReader.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/io/OsgFactory.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/io/WktWriter.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/io/Serialization.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/ComplexComparator.h
-- Installing: /usr/local/./include/SFCGAL/detail/generator
-- Up-to-date: /usr/local/./include/SFCGAL/detail/generator/building.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/generator/hoch.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/generator/sierpinski.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/generator/disc.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/TestGeometry.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/EnvelopeVisitor.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/GeometrySet.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/ublas.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/Interval.h
-- Installing: /usr/local/./include/SFCGAL/detail/triangulate
-- Up-to-date: /usr/local/./include/SFCGAL/detail/triangulate/markDomains.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/triangulate/ConstraintDelaunayTriangulation.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/triangulate/triangulateInGeometrySet.h
-- Up-to-date: /usr/local/./include/SFCGAL/detail/GetPointsVisitor.h
-- Up-to-date: /usr/local/./include/SFCGAL/config.h.cmake
-- Up-to-date: /usr/local/./include/SFCGAL/Transform.h
-- Up-to-date: /usr/local/./include/SFCGAL/PolyhedralSurface.h
-- Up-to-date: /usr/local/./include/SFCGAL/Coordinate.h
-- Up-to-date: /usr/local/./include/SFCGAL/Solid.h
-- Up-to-date: /usr/local/./include/SFCGAL/Polygon.h
-- Up-to-date: /usr/local/./include/SFCGAL/TriangulatedSurface.h
-- Installing: /usr/local/./include/SFCGAL/triangulate
-- Up-to-date: /usr/local/./include/SFCGAL/triangulate/triangulatePolygon.h
-- Up-to-date: /usr/local/./include/SFCGAL/triangulate/triangulate2DZ.h
-- Up-to-date: /usr/local/./include/SFCGAL/PreparedGeometry.h
-- Up-to-date: /usr/local/./include/SFCGAL/Triangle.h
-- Installing: /usr/local/./include/CGAL
-- Up-to-date: /usr/local/./include/CGAL/README
-- Up-to-date: /usr/local/./include/CGAL/use.h
-- Installing: /usr/local/./include/CGAL/Intersections_2
-- Up-to-date: /usr/local/./include/CGAL/Intersections_2/Triangle_2_Triangle_2_intersection_impl.h
-- Installing: /usr/local/./include/CGAL/internal
-- Installing: /usr/local/./include/CGAL/internal/Operations_on_polyhedra
-- Up-to-date: /usr/local/./include/CGAL/internal/Operations_on_polyhedra/Ray_3_Triangle_3_traversal_traits.h
-- Up-to-date: /usr/local/./include/CGAL/internal/Operations_on_polyhedra/AABB_triangle_accessor_3_primitive.h
-- Up-to-date: /usr/local/./include/CGAL/intersection_of_Polyhedra_3_refinement_visitor.h
-- Up-to-date: /usr/local/./include/CGAL/Triangle_3_Ray_3_do_intersect.h
-- Up-to-date: /usr/local/./include/CGAL/Point_inside_polyhedron_3.h
-- Up-to-date: /usr/local/lib/libSFCGAL.la
-- Up-to-date: /usr/local/bin/sfcgal-config
-- Up-to-date: /usr/local/lib/libSFCGAL.so
