[postgis-devel] [postgis-users] linking 2 topogeometries of different nature
Rémi Cura remi.cura at gmail.com
Mon Oct 28 05:12:45 PDT 2013
Sorry I'm being very unclear.
And I totally agree with you, even if that's not a conceptual bug as the
function doesn't do this.
I prepared some images,
can I join it to mail to the list or is it forbidden?
Cheers,
Rémi-C
2013/10/28 Sandro Santilli <strk at keybit.net>
> On Mon, Oct 28, 2013 at 11:00:59AM +0100, Rémi Cura wrote:
> > Hey all,
> > Hey Sandro.
> > The first beta version of the function is completed.
> >  ** GetRelatedTopogeom(source_topo topogeometry, target_topo_layer_id
> INT);
> > It returns set of topogeometry of the layer target_topo_layer_id that may
> > be affected by a change in topogeometry source_topo.
> Uhm, I just realized there's a conceptual bug here.
> The only TopoGeometry objects that would be affected by a change in
> another TopoGeometry object are those used by hierarchical layers.
> TopoGeometry objects are only defined by relations, if you _change_
> a TopoGeometry you basically change its set of relations, which
> doesn't affect other sets.
> --strk;
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131028/2ae7ba8e/attachment.html>
