[postgis-devel] New function ST_DumpSegments?? (was : utility function : linestring -> setof segment)
Sandro Santilli strk at keybit.net
Wed Oct 30 09:07:08 PDT 2013
On Wed, Oct 30, 2013 at 04:57:49PM +0100, RĂ©mi Cura wrote:
> Perfect,
> what do you mean exactly by "testcase" and "documentation".
> How many tests, of which kind, and what formatting for documentation?
See other tests under regress/, for example regress/dump.sql
and regress/dumppointes.sql. See regress/README for more info
(The "How to add a regression test", the requirements part seems
outdated)
Documentation is in docbook format. See 'id="ST_DumpPoints"' in
doc/reference_processing.xml
> As it is the first time, I don't know how to do it.
> I wouldn't want to submit a bad patch !
Can always be improved :)
Feel free to send a pull request on github if you prefer
(but it still needs a trac ticket)
--strk;
