[postgis-devel] New function ST_DumpSegments?? (was : utility function : linestring -> setof segment)
Rémi Cura remi.cura at gmail.com
Wed Oct 30 09:32:44 PDT 2013
Ok
I think I understand the regress test.
I'll write the files and add name where required then test it (trying make
test?)
When it works I'll make an archive and then send (you ?)everything.
I'm not so confident about xml doc, I can copy-past and try to adapt, but I
will have no way to test it (or shall I use some command to build the doc?).
Cheers,
Rémi-C
2013/10/30 Sandro Santilli <strk at keybit.net>
> On Wed, Oct 30, 2013 at 04:57:49PM +0100, Rémi Cura wrote:
> > Perfect,
> > what do you mean exactly by "testcase" and "documentation".
> > How many tests, of which kind, and what formatting for documentation?
> See other tests under regress/, for example regress/dump.sql
> and regress/dumppointes.sql. See regress/README for more info
> (The "How to add a regression test", the requirements part seems
> outdated)
> Documentation is in docbook format. See 'id="ST_DumpPoints"' in
> doc/reference_processing.xml
> > As it is the first time, I don't know how to do it.
> > I wouldn't want to submit a bad patch !
> Can always be improved :)
> Feel free to send a pull request on github if you prefer
> (but it still needs a trac ticket)
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131030/9a38eac9/attachment.html>
