[postgis-devel] New function ST_DumpSegments?? (was : utility function : linestring -> setof segment)
Sandro Santilli strk at keybit.net
Wed Oct 30 09:38:28 PDT 2013
On Wed, Oct 30, 2013 at 05:32:44PM +0100, RĂ©mi Cura wrote:
> Ok
> I think I understand the regress test.
> I'll write the files and add name where required then test it (trying make
> test?)
make check.
Or you can run just your new test:
cd regress; ./run_test.pl -v dumpsegments.sql
> When it works I'll make an archive and then send (you ?)everything.
No!! :)
Do you know how to use git or svn ?
We need patches, not full archives.
SVN is the old way to do things, so if you have't learnt don't start now :P
> I'm not so confident about xml doc, I can copy-past and try to adapt, but I
> will have no way to test it (or shall I use some command to build the doc?).
cd doc && make check
--strk;
