[postgis-devel] New function ST_DumpSegments?? (was : utility function : linestring -> setof segment)
Rémi Cura remi.cura at gmail.com
Wed Oct 30 09:40:28 PDT 2013
Ok thanks.
I can't use neither svn nor github easily due to very strict firewall.
I was thinking about sending only modified files.
Cheers,
Rémi-C
2013/10/30 Sandro Santilli <strk at keybit.net>
> On Wed, Oct 30, 2013 at 05:32:44PM +0100, Rémi Cura wrote:
> > Ok
> > I think I understand the regress test.
> > I'll write the files and add name where required then test it (trying
> make
> > test?)
> make check.
> Or you can run just your new test:
> cd regress; ./run_test.pl -v dumpsegments.sql
> > When it works I'll make an archive and then send (you ?)everything.
> No!! :)
> Do you know how to use git or svn ?
> We need patches, not full archives.
> SVN is the old way to do things, so if you have't learnt don't start now :P
> > I'm not so confident about xml doc, I can copy-past and try to adapt,
> but I
> > will have no way to test it (or shall I use some command to build the
> doc?).
> cd doc && make check
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131030/43a6e809/attachment.html>
