[postgis-devel] What is the correct way to remove a sql-signature
Nicklas Avén nicklas.aven at jordogskog.no
Tue Sep 3 10:21:03 PDT 2013
Thanks Sandro
The problem was just that I had missed the connection between the doc
and comments, so I searched at the wrong place. I had forgotten to
update the doc according to the changed signature.
Since the signature was only there for a few weeks in the trunk I guess
I do not have to put anything in the upgrade scripts, right?
/Nicklas
On Mon, 2013-09-02 at 14:26 +0200, Sandro Santilli wrote:
> On Mon, Aug 26, 2013 at 01:23:30PM +0200, Nicklas Avén wrote:
> > Hallo
> > TWKB has changed to VarInts instead of my homebrewed compression method.
> > Then the byte order is defined n the VarInt concept so I have removed the option to decide byteorder of input.
> > But when I remove the sql-signatures with endianess option from postgis.sql.in and rerun configure I get into problems with comment.sql missing those functions.
> Are you saying that "./configure" complains ?
> Can you paste the exact error message ?
> > What is the right way to do this?
> > Is it just a question of triggering a new version of comment.sql or do I have to do some further changes?
> Regenerating comment.sql ( should be done by "make" ) should fix the
> problem, but if you remove a signature you should also put it into the
> postgis_drop_before.sql ( or postgis_drop_after.sql ) file for proper
> upgrading procedure.
> Changing signatures is always expensive, better to think a lot
> before adding any.
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
