[postgis-devel] PostGIS-2.0.4 ?
Sandro Santilli strk at keybit.net
Wed Sep 4 13:36:39 PDT 2013
What about cutting a 2.0.4 release ?
2.0.3 was released on March 1st, 2013
Changes since then:
 * Bug Fixes *
  - #2110, Equality operator between EMPTY and point on origin
  - Allow adding points at precision distance with TopoGeo_addPoint
  - #1968, Fix missing edge from toTopoGeom return
  - #2165, ST_NumPoints regression failure with CircularString
  - #2168, ST_Distance is not always commutative
  - #2186, gui progress bar updates too frequent
  - #2201, ST_GeoHash wrong on boundaries
  - #2257, GBOX variables not initialized when testing with empty geometries
  - #2271, Prevent parallel make of raster
  - #2267, Server crash from analyze table
  - #2277, potential segfault removed
  - #2307, ST_MakeValid outputs invalid geometries
  - #2351, st_distance between geographies wrong
  - #2359, Incorrect handling of schema for overview constraints
  - #2371, Support GEOS versions with more than 1 digit in micro
  - #2372, Cannot parse space-padded KML coordinates
  - Fix build with systemwide liblwgeom installed
  - #2383, Fix unsafe use of \' in warning message
  - #2410, Fix segmentize of collinear curve
  - #2415, ST_Multi support for COMPOUNDCURVE and CURVEPOLYGON
  - #2412, ST_LineToCurve support for lines with less than 4 vertices
  - #2420, ST_LineToCurve: require at least 8 edges to define a full circle
  - #2423, ST_LineToCurve: require all arc edges to form the same angle
  - #2424, ST_CurveToLine: add support for COMPOUNDCURVE in MULTICURVE
  - #2427, Make sure to retain first point of curves on ST_CurveToLine
 * Enhancements *
  - #2269, Avoid uselessly detoasting full geometries on ANALYZE
 * Known Issues *
  - #2111, Raster bands can only reference the first 256 bands of out-db rasters
There are 14 tickets targetted at 2.0.4, which make the most annoying part of
cutting the relase (they should be moved upward, maybe to 2.1.1 directly...).
http://trac.osgeo.org/postgis/query?status=assigned&status=new&status=reopened&order=priority&col=id&col=summary&col=status&col=type&col=priority&col=milestone&col=component&milestone=PostGIS+2.0.4
What do you think ?
--strk;
 http://www.cartodb.com - Map, analyze and build applications with your data
                                       ~~ http://strk.keybit.net
