[postgis-devel] Cannot install postgis.control, when raster is disabled on RHEL 6
maplabs at light42.com maplabs at light42.com
Fri Sep 20 16:46:26 PDT 2013
Hi Devrim -
  when I build and install from source, and I want the EXTENSION
mechanism, I explicitly cd to /extensions/ then
make; sudo make install
  there is something mentioned about that in /extensions/README/
best regards from San Francisco, California
Brian M Hamlin
OSGeo California Chapter
On Sat, 21 Sep 2013 00:56:08 +0300, Devrim GÜNDÜZ  wrote:
I have a packaging issue that I need your help to solve.
On RHEL 6, make install does not install postgis.control and
postgis-*.sql files related to psotgis.control. That is breaking the
packages badly.
When I tried to run make under extensions/postgis directory, I'm getting
this:
-bash-4.1$ make
make: *** No rule to make target `../../raster/rt_pg/rtpostgis.sql',
needed by `sql_bits/rtpostgis.sql'.  Stop.
Do we really need rtpostgis.sql for postgis.control?
Regards,
Devrim GÜNDÜZ
Principal Systems Engineer @ EnterpriseDB: http://www.enterprisedb.com
PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
Community: devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
http://www.gunduz.org  Twitter: http://twitter.com/devrimgunduz
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130920/07237909/attachment.html>
