[postgis-devel] Cannot install postgis.control, when raster is disabled on RHEL 6
Mike Toews mwtoews at gmail.com
Sun Sep 22 18:05:49 PDT 2013
On 21 September 2013 09:56, Devrim GÜNDÜZ <devrim at gunduz.org> wrote:
> Hi,
> I have a packaging issue that I need your help to solve.
> On RHEL 6, make install does not install postgis.control and
> postgis-*.sql files related to psotgis.control. That is breaking the
> packages badly.
> When I tried to run make under extensions/postgis directory, I'm getting
> this:
> -bash-4.1$ make
> make: *** No rule to make target `../../raster/rt_pg/rtpostgis.sql',
> needed by `sql_bits/rtpostgis.sql'.  Stop.
> Do we really need rtpostgis.sql for postgis.control?
Is this build of PostGIS configured --without-raster? If so, then the
EXTENSION support and .control files are not built.
-Mike
