[postgis-devel] a slight error in postgis TopologySummary
Sandro Santilli strk at keybit.net
Thu Sep 26 06:59:37 PDT 2013
On Thu, Sep 26, 2013 at 03:29:36PM +0200, RĂ©mi Cura wrote:
> Hello strk,
> I'm not using the latest yet :
> POSTGIS="2.0.3 r11128" GEOS="3.4.0dev-CAPI-1.8.0 r3857" PROJ="Rel. 4.8.0, 6
> March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.8.0" TOPOLOGY
> RASTER
> Quick fix : a minor change in design : was querying the wrong table.
> On my version it's around lines 68-70 in the function definition.
> Old version :
> "EXECUTE 'SELECT count(*) FROM (SELECT DISTINCT layer_id FROM '
>       || quote_ident(atopology) || '.relation ) foo ' INTO STRICT n;
> New version :
> topology.layer
>  WHERE schema_name = '|| quote_literal(atopology) || ') foo ' INTO STRICT
> n;"
You're confusing layer _deploy_ schema_name with schema containing
the topological primitives. The correct query could be:
    EXECUTE 'SELECT count(layer_id) FROM topology.layer WHERE topology_id = '
      || rec.id INTO STRICT n;
Can you give that a try ?
--strk;
