[postgis-devel] sfcgal && extensions
Paul Ramsey pramsey at cleverelephant.ca
Fri Sep 27 11:46:08 PDT 2013
It looks to me like sfcgal.sql never gets added to the postgis extension, even when it's been built and enabled... so there's no way to use the cgal functions in an extension context, only if you manually load the sfcgal.sql file yourself. Correct interpretation?
P
Paul Ramsey
http://cleverelephant.ca
http://postgis.net
