[postgis-devel] PSC/Development Vote -- Baris to release upcoming 2.1.3 jars and manually sign
Baris Ergun
barisergun75 at gmail.com
Fri Apr 25 13:53:11 PDT 2014
Completed the task and tested the building of artifacts on branches/2.1
basically now we have separate jdbc and jdbc_jtsparser projects (which must
be built consecutively). Do we have an continuous integration server where
I can integrate? Otherwise I will have to ask for your help on verification.
On 24 April 2014 13:41, Baris Ergun <barisergun75 at gmail.com> wrote:
> Okey than will start soon.
> On 22 April 2014 22:38, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>> make it so +1
>> On Sat, Apr 19, 2014 at 5:52 PM, Bborie Park <dustymugs at gmail.com> wrote:
>> > +1 for release of 2.1.3 jar.
>> > On Sat, Apr 19, 2014 at 5:47 PM, Paragon Corporation <lr at pcorp.us>
>> wrote:
>> >> Baris,
>> >> Regarding this:
>> >> > Here is my proposal: I can take care of the last targeted 2.1
>> release
>> >> > which is 2.1.3 and change pom.xmls as I did in the trunk and apply
>> shanes
>> >> > patches and after the release of 2.1.3 I can manually sign the jars
>> and
>> >> > submit them to OSSRH. And keep discussing the separation of
>> >> > repositories on trunk.
>> >> +1 for that. Others in PSC and development please vote on this as
>> well so
>> >> we can start moving on this.
>> >> I think we'll be releasing a 2.1.3 fairly soon. 2.2.0 we are looking
>> at
>> >> at least another 4 months and that's being hopeful :)
>> >> Thanks,
>> >> Regina
>> >> http://www.postgis.us
>> >> http://postgis.net
>> >> ________________________________
>> >> From: postgis-users-bounces at lists.osgeo.org
>> >> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Baris
>> Ergun
>> >> Sent: Saturday, April 19, 2014 4:50 AM
>> >> To: PostGIS Users Discussion
>> >> Cc: PostGIS Development Discussion
>> >> Subject: Re: [postgis-users] [postgis-devel] looking for a public well
>> >> known maven repository for postgis-jdbc 2.1 and later on versions
>> >> Hi Shane;
>> >> People are busy with other stuff so until we decide to separate the
>> >> repositories for postgis java projects I have applied ur patches to
>> both
>> >> jdbc and jdbc_jtsparser projects. So what this means is "when we
>> release
>> >> 2.2.0 postgis I would be ready to submit these two jars manually to
>> OSSRH".
>> >> Baris
>> >> On 7 April 2014 21:26, Shane StClair <shane at axiomalaska.com> wrote:
>> >>> Hi Baris,
>> >>> Oops, I didn't see that you were already chasing this down. Your
>> approach
>> >>> sounds great, thanks for taking the lead on this! In the past there
>> have
>> >>> been issues with other projects having non-resolvable dependencies on
>> >>> versions of postgis-jdbc (Hibernate Spatial), so it will be great to
>> have
>> >>> these artifacts in the central repo.
>> >>> Best,
>> >>> Shane
>> >>> On Sun, Apr 6, 2014 at 2:29 AM, Baris Ergun <barisergun75 at gmail.com>
>> >>> wrote:
>> >>>> Hi Shane;
>> >>>> Thanks for ur patch and consideration. I think we are on the same
>> path
>> >>>> if u check the issue #2626. I have applied the OSSRH and got the
>> credentials
>> >>>> for being able to upload postgis jdbc jars to central maven rep. For
>> that
>> >>>> case I have separated the jdbc and jdbc-jtsparser jars on the trunk
>> and
>> >>>> updated the pom.xml's according to Central maven repository
>> requirements..
>> >>>> On the trunk actually I was waiting to agree with all the
>> developers to
>> >>>> separate the postgis jdbc jars repository and continue with 1st
>> suggested
>> >>>> approach. If we do that way we wouldnt need to make the explicit
>> plugin
>> >>>> declarations as you patched in 2702.
>> release
>> shanes
>> and
>> repositories on
>> >>>> trunk.
>> >>>> On 6 April 2014 05:32, Paragon Corporation <lr at pcorp.us> wrote:
>> >>>>> I don't have any objections. +1 for that.
>> >>>>> Thanks,
>> >>>>> Regina
>> >>>>> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Shane
>> StClair
>> >>>>> Sent: Saturday, April 05, 2014 5:24 PM
>> >>>>> Subject: Re: [postgis-users] looking for a public well known maven
>> >>>>> Sounds good. Any objection to the community manually uploading
>> pre-2.2
>> >>>>> versions to Maven Central?
>> >>>>> Thanks,
>> >>>>> Shane
>> >>>>> On Sat, Apr 5, 2014 at 1:38 PM, Paragon Corporation <lr at pcorp.us>
>> >>>>> wrote:
>> >>>>>> Shane,
>> >>>>>> I think we can change our build bot to upload to maven as part of
>> the
>> >>>>>> official release job when we build tagged docs etc. Have to talk
>> over with
>> >>>>>> rest of PostGIS psc and dev folks on that.
>> >>>>>> I guess before that we'll need to completely cleanup the issues
>> with
>> >>>>>> our current jdbc which sounds like we are close. Thanks for the
>> patch BTW.
>> >>>>>> Thanks,
>> >>>>>> Regina Obe
>> >>>>>> PostGIS PSC member
>> >>>>>> http://postgis.net
>> StClair
>> >>>>>> Sent: Saturday, April 05, 2014 3:29 PM
>> >>>>>> To: postgis-users at lists.osgeo.org
>> >>>>>> Subject: [postgis-users] looking for a public well known maven
>> >>>>>> I just submitted a patch [1] to generate javadoc and source jars as
>> >>>>>> part of the postgis-jdbc build. Otherwise, the existing pom meets
>> the Maven
>> >>>>>> Central sync requirements [2].
>> >>>>>> There are two options for getting up to date postgis-jdbc releases
>> >>>>>> into Maven Central. The first would be for Maven Central
>> deployment to
>> >>>>>> become part of the postgis release process. After the initial
>> setup the
>> >>>>>> Maven Central publishing process isn't terribly painful, but it
>> would
>> >>>>>> require a postgis developer to assume responsibility for the Maven
>> Central
>> >>>>>> submission and for postgis-jdbc to get special consideration
>> during releases
>> >>>>>> [3] [4].
>> >>>>>> The other option would be to have the community manually upload to
>> >>>>>> Maven Central [5]. This is definitely not the ideal situation, but
>> if Maven
>> >>>>>> Central uploads are out of scope for the postgis devs right now it
>> would
>> >>>>>> allow us to get updated versions into the central repo. A blessing
>> from the
>> >>>>>> postgis devs would help in this second case.
>> >>>>>> Thanks,
>> >>>>>> Shane
>> >>>>>> [1] http://trac.osgeo.org/postgis/ticket/2702
>> >>>>>> [2]
>> https://docs.sonatype.org/display/Repository/Central+Sync+Requirements
>> >>>>>> [3]
>> https://maven.apache.org/guides/mini/guide-central-repository-upload.html
>> >>>>>> [4] http://central.sonatype.org/pages/ossrh-guide.html
>> >>>>>> [5]
>> https://docs.sonatype.org/display/Repository/Uploading+3rd-party+Artifacts+to+The+Central+Repository
>> >>>>>> Shane StClair
>> >>>>>> Software Engineer
>> >>>>>> Axiom Consulting & Design
>> >>>>>> http://www.axiomalaska.com
>> >>>>>> _______________________________________________
>> >>>>>> postgis-users mailing list
>> >>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> >>>>> Shane StClair
>> >>>>> Software Engineer
>> >>>>> postgis-devel mailing list
>> >>>>> postgis-devel at lists.osgeo.org
>> >>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
>> >>>> Barış
>> >>> Shane StClair
>> >>> Software Engineer
>> >> Barış
> Barış
Barış
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140425/13fd1a88/attachment.html>
