[postgis-devel] PSC/Development Vote -- Baris to release upcoming 2.1.3 jars and manually sign
Baris Ergun barisergun75 at gmail.com
Sat Apr 26 11:08:07 PDT 2014
Hi;
Only that jdbc_jtsparser project can also be added to Jenkins projects for
both branches/2.1 and trunk. No other specific script necessary.
(java/jdbc_jtsparser) running  'mvn clean install' on code changes would be
enough.
Thanks.
Baris.
On 26 April 2014 07:06, Paragon Corporation <lr at pcorp.us> wrote:
>  Baris,
> Yes we do have  a continuous integration bot. Do you have a script I can
> schedule her to run or is what is running so far okay.
> Currently have this job which runs for jdbc.
> http://debbie.postgis.net:8080/view/PostGIS/job/PostGIS_2.1_JDBC/
>  As far as I can tell last run was successful
> http://debbie.postgis.net:8080/view/PostGIS/job/PostGIS_2.1_JDBC/558/console
> If you do have a script, just commit it to this folder:
> http://trac.osgeo.org/postgis/browser/buildbots/debian/scripts
> (I don't have all her scripts in subversion yet but is on my todo)
> Thanks,
> Regina
> *From:* postgis-devel-bounces at lists.osgeo.org [mailto:
> postgis-devel-bounces at lists.osgeo.org] *On Behalf Of *Baris Ergun
> *Sent:* Friday, April 25, 2014 4:53 PM
> *To:* PostGIS Development Discussion
> *Subject:* Re: [postgis-devel] PSC/Development Vote -- Baris to release
>  Completed the task and tested the building of artifacts on branches/2.1
> basically now we have separate jdbc and jdbc_jtsparser projects (which must
> be built consecutively). Do we have an continuous integration server where
> I can integrate? Otherwise I will have to ask for your help on verification.
> On 24 April 2014 13:41, Baris Ergun <barisergun75 at gmail.com> wrote:
>> Okey than will start soon.
>> On 22 April 2014 22:38, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>>> make it so +1
>>> On Sat, Apr 19, 2014 at 5:52 PM, Bborie Park <dustymugs at gmail.com>
>>> wrote:
>>> > +1 for release of 2.1.3 jar.
>>> > On Sat, Apr 19, 2014 at 5:47 PM, Paragon Corporation <lr at pcorp.us>
>>> wrote:
>>> >> Baris,
>>> >> Regarding this:
>>> >> > Here is my proposal: I can take care of the last  targeted 2.1
>>> release
>>> >> > which is 2.1.3 and change pom.xmls as I did in the trunk and apply
>>> shanes
>>> >> > patches and after the release of 2.1.3 I can manually sign the jars
>>> and
>>> >> > submit them to OSSRH. And keep discussing the separation of
>>> >> > repositories on trunk.
>>> >> +1 for that.  Others in PSC and development please vote on this as
>>> well so
>>> >> we can start moving on this.
>>> >> I think we'll be releasing a 2.1.3 fairly soon.  2.2.0 we are looking
>>> at
>>> >> at least another 4 months and that's being hopeful :)
>>> >> Thanks,
>>> >> Regina
>>> >> http://www.postgis.us
>>> >> http://postgis.net
>>> >> ________________________________
>>> >> From: postgis-users-bounces at lists.osgeo.org
>>> >> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Baris
>>> Ergun
>>> >> Sent: Saturday, April 19, 2014 4:50 AM
>>> >> To: PostGIS Users Discussion
>>> >> Cc: PostGIS Development Discussion
>>> >> Subject: Re: [postgis-users] [postgis-devel] looking for a public well
>>> >> known maven repository for postgis-jdbc 2.1 and later on versions
>>> >> Hi Shane;
>>> >> People are busy with other stuff so until we decide to separate the
>>> >> repositories for postgis java projects I have applied ur patches to
>>> both
>>> >> jdbc and jdbc_jtsparser projects. So what this means is "when we
>>> release
>>> >> 2.2.0 postgis I would be ready to submit these two jars manually to
>>> OSSRH".
>>> >> Baris
>>> >> On 7 April 2014 21:26, Shane StClair <shane at axiomalaska.com> wrote:
>>> >>> Hi Baris,
>>> >>> Oops, I didn't see that you were already chasing this down. Your
>>> approach
>>> >>> sounds great, thanks for taking the lead on this! In the past there
>>> have
>>> >>> been issues with other projects having non-resolvable dependencies on
>>> >>> versions of postgis-jdbc (Hibernate Spatial), so it will be great to
>>> have
>>> >>> these artifacts in the central repo.
>>> >>> Best,
>>> >>> Shane
>>> >>> On Sun, Apr 6, 2014 at 2:29 AM, Baris Ergun <barisergun75 at gmail.com>
>>> >>> wrote:
>>> >>>> Hi Shane;
>>> >>>> Thanks for ur patch and consideration. I think we are on the same
>>> path
>>> >>>> if u check the issue #2626. I have applied the OSSRH and got the
>>> credentials
>>> >>>> for being able to upload postgis jdbc jars to central maven rep.
>>> For that
>>> >>>> case I have separated the jdbc and jdbc-jtsparser jars on the trunk
>>> and
>>> >>>> updated the pom.xml's according to Central maven repository
>>> requirements..
>>> >>>> On the trunk actually I was waiting to agree  with all the
>>> developers to
>>> >>>> separate the postgis jdbc jars  repository and continue with 1st
>>> suggested
>>> >>>> approach.  If we do that way we wouldnt need to make the explicit
>>> plugin
>>> >>>> declarations as you patched in 2702.
>>> release
>>> shanes
>>> and
>>> repositories on
>>> >>>> trunk.
>>> >>>> On 6 April 2014 05:32, Paragon Corporation <lr at pcorp.us> wrote:
>>> >>>>> I don't have any objections.  +1 for that.
>>> >>>>> Thanks,
>>> >>>>> Regina
>>> >>>>> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Shane
>>> StClair
>>> >>>>> Sent: Saturday, April 05, 2014 5:24 PM
>>> >>>>> Subject: Re: [postgis-users] looking for a public well known maven
>>> >>>>> Sounds good. Any objection to the community manually uploading
>>> pre-2.2
>>> >>>>> versions to Maven Central?
>>> >>>>> Thanks,
>>> >>>>> Shane
>>> >>>>> On Sat, Apr 5, 2014 at 1:38 PM, Paragon Corporation <lr at pcorp.us>
>>> >>>>> wrote:
>>> >>>>>> Shane,
>>> >>>>>> I think we can change our build bot to upload to maven as part of
>>> the
>>> >>>>>> official release job when we build tagged docs etc.  Have to talk
>>> over with
>>> >>>>>> rest of PostGIS psc and dev folks on that.
>>> >>>>>> I guess before that we'll need to completely cleanup the issues
>>> with
>>> >>>>>> our current jdbc which sounds like we are close.  Thanks for the
>>> patch BTW.
>>> >>>>>> Thanks,
>>> >>>>>> Regina Obe
>>> >>>>>> PostGIS PSC member
>>> >>>>>> http://postgis.net
>>> Shane StClair
>>> >>>>>> Sent: Saturday, April 05, 2014 3:29 PM
>>> >>>>>> To: postgis-users at lists.osgeo.org
>>> >>>>>> Subject: [postgis-users] looking for a public well known maven
>>> >>>>>> I just submitted a patch [1] to generate javadoc and source jars
>>> as
>>> >>>>>> part of the postgis-jdbc build. Otherwise, the existing pom meets
>>> the Maven
>>> >>>>>> Central sync requirements [2].
>>> >>>>>> There are two options for getting up to date postgis-jdbc releases
>>> >>>>>> into Maven Central. The first would be for Maven Central
>>> deployment to
>>> >>>>>> become part of the postgis release process. After the initial
>>> setup the
>>> >>>>>> Maven Central publishing process isn't terribly painful, but it
>>> would
>>> >>>>>> require a postgis developer to assume responsibility for the
>>> Maven Central
>>> >>>>>> submission and for postgis-jdbc to get special consideration
>>> during releases
>>> >>>>>> [3] [4].
>>> >>>>>> The other option would be to have the community manually upload to
>>> >>>>>> Maven Central [5]. This is definitely not the ideal situation,
>>> but if Maven
>>> >>>>>> Central uploads are out of scope for the postgis devs right now
>>> it would
>>> >>>>>> allow us to get updated versions into the central repo. A
>>> blessing from the
>>> >>>>>> postgis devs would help in this second case.
>>> >>>>>> Thanks,
>>> >>>>>> Shane
>>> >>>>>> [1] http://trac.osgeo.org/postgis/ticket/2702
>>> >>>>>> [2]
>>> https://docs.sonatype.org/display/Repository/Central+Sync+Requirements
>>> >>>>>> [3]
>>> https://maven.apache.org/guides/mini/guide-central-repository-upload.html
>>> >>>>>> [4] http://central.sonatype.org/pages/ossrh-guide.html
>>> >>>>>> [5]
>>> https://docs.sonatype.org/display/Repository/Uploading+3rd-party+Artifacts+to+The+Central+Repository
>>> >>>>>> Shane StClair
>>> >>>>>> Software Engineer
>>> >>>>>> Axiom Consulting & Design
>>> >>>>>> http://www.axiomalaska.com
>>> >>>>>> _______________________________________________
>>> >>>>>> postgis-users mailing list
>>> >>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>> >>>>> Shane StClair
>>> >>>>> Software Engineer
>>> >>>>> postgis-devel mailing list
>>> >>>>> postgis-devel at lists.osgeo.org
>>> >>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
>>> >>>> Barış
>>> >>> Shane StClair
>>> >>> Software Engineer
>>> >> Barış
>> Barış
> Barış
Barış
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140426/592e8764/attachment.html>
