[postgis-devel] PSC/Development Vote -- Baris to release upcoming 2.1.3 jars and manually sign
Baris Ergun barisergun75 at gmail.com
Mon Apr 28 22:53:32 PDT 2014
On 28 April 2014 21:55, Paragon Corporation <lr at pcorp.us> wrote:
>  Baris,
> Possibly stupid questions
> 1) What is the jdbc_jtsparser for vs. the current jdbc
It is basically Parser between JTS and PostGIS geometry formats. So that
for instance if someone uses JTS( Java Toplogy Suite) 2D Geometry objects
on her/him POJOs it is there for binary writing to or binary reading from
postgresql database. It was tailored long time ago and was put under
jdbc/jtssrc folder. So I just moved it out of that folder and made it a
separate maven project which is depending on the artifact of main jdbc
project. It depends on it because it is build on top of the DriverWrapper
and ByteGetter ByteSetter, StringByteGetter , ValueSetter like classes. In
other words Jdbc handling is in jdbc project, jtsparser brings support for
JTS classes on top of it.
> 2) Can we have parent pom at root of Java that runs the child poms
Perfectly yes.  I may prepare a pom only project under java named
postgis_maven_parent and make those 2 projects use it. It also will have
advantage of reusing pluginManagement pom.xml definitions on both projects.
> right now in Jenkins I have two separate jobs going -- 1 to build the
> jdbc and one to build the jdbc_jtsparser. Both get dumped here:
> http://postgis.net/stuff/
>  For some reason (possibly ineptness on my part), I can't get this into
> one maven job.
> It's my understanding that if we have a parent pom (possibly in java
> folder), I can just call that to build both.
> http://stackoverflow.com/questions/13988469/maven-multi-module-pom-and-jenkins-jobs
> Is that possible or am I totally misunderstanding this.
> Thanks,
> Regina
> *From:* postgis-devel-bounces at lists.osgeo.org [mailto:
> postgis-devel-bounces at lists.osgeo.org] *On Behalf Of *Baris Ergun
> *Sent:* Saturday, April 26, 2014 2:08 PM
> *To:* PostGIS Development Discussion
> *Subject:* Re: [postgis-devel] PSC/Development Vote -- Baris to release
>  Hi;
> Only that jdbc_jtsparser project can also be added to Jenkins projects for
> both branches/2.1 and trunk. No other specific script necessary.
> (java/jdbc_jtsparser) running  'mvn clean install' on code changes would be
> enough.
> Thanks.
> Baris.
> On 26 April 2014 07:06, Paragon Corporation <lr at pcorp.us> wrote:
>>  Baris,
>> Yes we do have  a continuous integration bot. Do you have a script I can
>> schedule her to run or is what is running so far okay.
>> Currently have this job which runs for jdbc.
>> http://debbie.postgis.net:8080/view/PostGIS/job/PostGIS_2.1_JDBC/
>>  As far as I can tell last run was successful
>> http://debbie.postgis.net:8080/view/PostGIS/job/PostGIS_2.1_JDBC/558/console
>> If you do have a script, just commit it to this folder:
>> http://trac.osgeo.org/postgis/browser/buildbots/debian/scripts
>> (I don't have all her scripts in subversion yet but is on my todo)
>> Thanks,
>> Regina
>> *Sent:* Friday, April 25, 2014 4:53 PM
>>   Completed the task and tested the building of artifacts on
>> branches/2.1 basically now we have separate jdbc and jdbc_jtsparser
>> projects (which must be built consecutively). Do we have an continuous
>> integration server where I can integrate? Otherwise I will have to ask for
>> your help on verification.
>> On 24 April 2014 13:41, Baris Ergun <barisergun75 at gmail.com> wrote:
>>> Okey than will start soon.
>>> On 22 April 2014 22:38, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>>>> make it so +1
>>>> On Sat, Apr 19, 2014 at 5:52 PM, Bborie Park <dustymugs at gmail.com>
>>>> wrote:
>>>> > +1 for release of 2.1.3 jar.
>>>> > On Sat, Apr 19, 2014 at 5:47 PM, Paragon Corporation <lr at pcorp.us>
>>>> wrote:
>>>> >> Baris,
>>>> >> Regarding this:
>>>> >> > Here is my proposal: I can take care of the last  targeted 2.1
>>>> release
>>>> >> > which is 2.1.3 and change pom.xmls as I did in the trunk and apply
>>>> shanes
>>>> >> > patches and after the release of 2.1.3 I can manually sign the
>>>> jars and
>>>> >> > submit them to OSSRH. And keep discussing the separation of
>>>> >> > repositories on trunk.
>>>> >> +1 for that.  Others in PSC and development please vote on this as
>>>> well so
>>>> >> we can start moving on this.
>>>> >> I think we'll be releasing a 2.1.3 fairly soon.  2.2.0 we are
>>>> looking at
>>>> >> at least another 4 months and that's being hopeful :)
>>>> >> Thanks,
>>>> >> Regina
>>>> >> http://www.postgis.us
>>>> >> http://postgis.net
>>>> >> ________________________________
>>>> >> From: postgis-users-bounces at lists.osgeo.org
>>>> >> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Baris
>>>> Ergun
>>>> >> Sent: Saturday, April 19, 2014 4:50 AM
>>>> >> To: PostGIS Users Discussion
>>>> >> Cc: PostGIS Development Discussion
>>>> >> Subject: Re: [postgis-users] [postgis-devel] looking for a public
>>>> well
>>>> >> known maven repository for postgis-jdbc 2.1 and later on versions
>>>> >> Hi Shane;
>>>> >> People are busy with other stuff so until we decide to separate the
>>>> >> repositories for postgis java projects I have applied ur patches to
>>>> both
>>>> >> jdbc and jdbc_jtsparser projects. So what this means is "when we
>>>> release
>>>> >> 2.2.0 postgis I would be ready to submit these two jars manually to
>>>> OSSRH".
>>>> >> Baris
>>>> >> On 7 April 2014 21:26, Shane StClair <shane at axiomalaska.com> wrote:
>>>> >>> Hi Baris,
>>>> >>> Oops, I didn't see that you were already chasing this down. Your
>>>> approach
>>>> >>> sounds great, thanks for taking the lead on this! In the past there
>>>> have
>>>> >>> been issues with other projects having non-resolvable dependencies
>>>> on
>>>> >>> versions of postgis-jdbc (Hibernate Spatial), so it will be great
>>>> to have
>>>> >>> these artifacts in the central repo.
>>>> >>> Best,
>>>> >>> Shane
>>>> >>> On Sun, Apr 6, 2014 at 2:29 AM, Baris Ergun <barisergun75 at gmail.com
>>>> >>> wrote:
>>>> >>>> Hi Shane;
>>>> >>>> Thanks for ur patch and consideration. I think we are on the same
>>>> path
>>>> >>>> if u check the issue #2626. I have applied the OSSRH and got the
>>>> credentials
>>>> >>>> for being able to upload postgis jdbc jars to central maven rep.
>>>> For that
>>>> >>>> case I have separated the jdbc and jdbc-jtsparser jars on the
>>>> trunk and
>>>> >>>> updated the pom.xml's according to Central maven repository
>>>> requirements..
>>>> >>>> On the trunk actually I was waiting to agree  with all the
>>>> developers to
>>>> >>>> separate the postgis jdbc jars  repository and continue with 1st
>>>> suggested
>>>> >>>> approach.  If we do that way we wouldnt need to make the explicit
>>>> plugin
>>>> >>>> declarations as you patched in 2702.
>>>> release
>>>> shanes
>>>> jars and
>>>> repositories on
>>>> >>>> trunk.
>>>> >>>> On 6 April 2014 05:32, Paragon Corporation <lr at pcorp.us> wrote:
>>>> >>>>> I don't have any objections.  +1 for that.
>>>> >>>>> Thanks,
>>>> >>>>> Regina
>>>> Shane StClair
>>>> >>>>> Sent: Saturday, April 05, 2014 5:24 PM
>>>> >>>>> Subject: Re: [postgis-users] looking for a public well known maven
>>>> >>>>> Sounds good. Any objection to the community manually uploading
>>>> pre-2.2
>>>> >>>>> versions to Maven Central?
>>>> >>>>> Thanks,
>>>> >>>>> Shane
>>>> >>>>> On Sat, Apr 5, 2014 at 1:38 PM, Paragon Corporation <lr at pcorp.us>
>>>> >>>>> wrote:
>>>> >>>>>> Shane,
>>>> >>>>>> I think we can change our build bot to upload to maven as part
>>>> of the
>>>> >>>>>> official release job when we build tagged docs etc.  Have to
>>>> talk over with
>>>> >>>>>> rest of PostGIS psc and dev folks on that.
>>>> >>>>>> I guess before that we'll need to completely cleanup the issues
>>>> with
>>>> >>>>>> our current jdbc which sounds like we are close.  Thanks for the
>>>> patch BTW.
>>>> >>>>>> Thanks,
>>>> >>>>>> Regina Obe
>>>> >>>>>> PostGIS PSC member
>>>> >>>>>> http://postgis.net
>>>> Shane StClair
>>>> >>>>>> Sent: Saturday, April 05, 2014 3:29 PM
>>>> >>>>>> To: postgis-users at lists.osgeo.org
>>>> >>>>>> Subject: [postgis-users] looking for a public well known maven
>>>> >>>>>> I just submitted a patch [1] to generate javadoc and source jars
>>>> as
>>>> >>>>>> part of the postgis-jdbc build. Otherwise, the existing pom
>>>> meets the Maven
>>>> >>>>>> Central sync requirements [2].
>>>> >>>>>> There are two options for getting up to date postgis-jdbc
>>>> releases
>>>> >>>>>> into Maven Central. The first would be for Maven Central
>>>> deployment to
>>>> >>>>>> become part of the postgis release process. After the initial
>>>> setup the
>>>> >>>>>> Maven Central publishing process isn't terribly painful, but it
>>>> would
>>>> >>>>>> require a postgis developer to assume responsibility for the
>>>> Maven Central
>>>> >>>>>> submission and for postgis-jdbc to get special consideration
>>>> during releases
>>>> >>>>>> [3] [4].
>>>> >>>>>> The other option would be to have the community manually upload
>>>> to
>>>> >>>>>> Maven Central [5]. This is definitely not the ideal situation,
>>>> but if Maven
>>>> >>>>>> Central uploads are out of scope for the postgis devs right now
>>>> it would
>>>> >>>>>> allow us to get updated versions into the central repo. A
>>>> blessing from the
>>>> >>>>>> postgis devs would help in this second case.
>>>> >>>>>> Thanks,
>>>> >>>>>> Shane
>>>> >>>>>> [1] http://trac.osgeo.org/postgis/ticket/2702
>>>> >>>>>> [2]
>>>> https://docs.sonatype.org/display/Repository/Central+Sync+Requirements
>>>> >>>>>> [3]
>>>> https://maven.apache.org/guides/mini/guide-central-repository-upload.html
>>>> >>>>>> [4] http://central.sonatype.org/pages/ossrh-guide.html
>>>> >>>>>> [5]
>>>> https://docs.sonatype.org/display/Repository/Uploading+3rd-party+Artifacts+to+The+Central+Repository
>>>> >>>>>> Shane StClair
>>>> >>>>>> Software Engineer
>>>> >>>>>> Axiom Consulting & Design
>>>> >>>>>> http://www.axiomalaska.com
>>>> >>>>>> _______________________________________________
>>>> >>>>>> postgis-users mailing list
>>>> >>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>> >>>>> Shane StClair
>>>> >>>>> Software Engineer
>>>> >>>>> postgis-devel mailing list
>>>> >>>>> postgis-devel at lists.osgeo.org
>>>> >>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
>>>> >>>> Barış
>>>> >>> Shane StClair
>>>> >>> Software Engineer
>>>> >> Barış
>>> Barış
>> Barış
> Barış
Barış
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140429/84427e96/attachment.html>
